Speakers plays fine for a few minutes, but then a static sound builds up and the speaker pops and no sound comes from it. The sound comes back once I reconnect the power source and fiddle with the power plug. Again it will be fine for a few seconds and then the problem repeats.
Look for a wire strand or solder splash on any circuit boards or connections that might be 'almost' shorting out anything. Next, if there are any metal screws with very pointy tips (like sheet metal screws) that might be just a smidge too long and clip the very tip off so that it can't possibly short a frame to a component.
The idea is to find any reason why electricity might be bleeding over into another area of a circuit board that uses capacitors where a charge could build up causing the symptom you are describing.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DA4ES-Receivers-manual/id/387ag919/t/2/
Page 79 - 120 watts maximum
Try turning it off with a different source selected. Or disable the speakers because you
