Amazon Kindle Fire HD Logo
R
Ron Hewson Posted on Apr 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kindle is about 4 years old and still works reasonably well but needs a reviving, can I reset to factory settings then reload the as if new?
Kevin K.
Level 2:
Sergeant:
  • Expert 251 Answers
  • Posted on Apr 16, 2016
Kevin K.
Expert
Level 2:
Sergeant:
Answers
251
Questions
0
Helped
104589
Points
865
To reset your Kindle, press or tap the "Menu" button on the Home screen and select "Settings." The "Settings" screen appears. Press or tap the "Menu" again and select "Reset to Factory Defaults." YourKindle will start the resetting process and power off automatically.
2answers
Fire tablet I can not get into setting with out password forgot it Have done the 5x enter word but not luck
Starting with the Kindle Fire off, press and hold "Volume Down" and "Power" simultaneously. The Amazon system recovery screen should appear. Use the volume buttons to toggle the selection to "wipe data/factory reset". Press the "Power" button to choose the selection.
How to Soft & Hard Reset Kindle Fire - Technipages
https://www.technipages.com > soft-hard-reset-kindle-fire
Please note you will lose all data on tablet. But you will get a working tablet back.
5answers
Want to transfer from "old kindle Fire AND Paper white to new kindle Fire
Copyright is translated as right to copy someone's original work. After copyright registration; an individual or business entity prohibits others from copying its original work. No one can imitate, infringe, copy or reproduce the copyrighted material. Copyright is valid for a term of 60 years in the territory of Bihar. Various work can be copyrighted such as music, movies, books, designs, paintings and more.
https://www.gsbtaxation.com/in/copyright-registration-in-bihar
2answers
When screen opens it suddenly starts asking for a password. I have never used a password, don't have one and cannot unlock my Kindle Fire HD
Give enter to password, in blank, withoul inputting anything. Maybe it accepts it as password.
The other possiblity is that you've been pranked and someone defined a password
Here you have a tutorial for Password Remove:
Kindle Fire Password Remove
If you can't get the password, you should do a Factory Reset.
Here you have some video tutorials how to do
Kindle Fire HD How to Reset Back to Factory Settings
Kindle Fire HD how to reset when locked up EpicReviewsTech CC
How to Factory Reset Amazon Kindle Fire Tablet Tutorial
Multiple problems with kindle fire. need to have it looked at and made functional. Tell me how to do this. Very confused and unhappy with seeking help.
You may need to go into settings and do factory reset. If you've had your info sent to cloud, it will reload all your info. You may just have to redo a few applications.
2answers
Amazon kindle suport web page
If I understand you correctly, you have a new Kindle Fire HD and would like to transfer the data from your old Kindle Fire to your new Kindle Fire HD. This is easy, follow these steps:
Step 1: Connect the old Kindle to Wireless. Pull down the upper status bar, select More + and then select My Account on the old Kindle
Step 2: Using the Old Kindle, select Deregister under My Account, let the task complete
Step 3: When the old Kindle has Deregistered, then pickup the new Kindle. If you accidentally registered this Kindle Deregister it and then Factory Reset the device.
Step 4: Now the old Kindle is Deregistered and the new Kindle is factory Fresh, let's begin the process.
Step 5: On the new Kindle, let's reboot after Factory Resetting the device. When the device powers back up you should be presented with a login Window. Go ahead and register the device to the same account as the Old Kindle. The sync process should begin automaticlly, it can take up to one full day to sync all your content.
Cannot coordinate amazon and kindle fire
Try a Factory Reset.
Step 1: Pull down the upper status bar, select More +
Step 2: Select Device - Reset to Factory Settings
Step 3: Wait for the process to complete
Step 4: Try to login to Amazon
3helpful
2answers
How to reset your kindle
Hey
To reboot or restore your kindle to factory setting do the following:
Hold the power button to the right for 20 secs
This will switch the kindle off
Hold the 'Home' button for 60 secs
The kindle reset screen will be displayed
To reboot the kindle without lose of files, press the 'Del' button
To restore to factory settings, type DELETE in the box provided
The kindle will restore once the final 'E' is entered
I hope the above helps and resolves your issue.
How to set password if we lost the old
Hey there,
If you cannot enter the password, you will need to reset your kindle back to factory settings. On the back panel, there is a small reset button: http://www.blogkindle.com/wp-content/uploads/2009/03/kindle-reset.gif
  1. First, you need something pointed like a paper clip or the tip of your earing.
  2. Now, open the back cover of your kindle by pressing it firmly while sliding it to the right using your thumbs.
  3. You will then see the reset button as shown on the picture. Use the paper-clip or your earing's pointed tip to press on the reset button.
  4. A few seconds after pressing the button, your kindle will then reboot and will be restored.
Note that you will need to reload all of your eBooks back onto the kindle after doing this.
Hope this helps, thanks for using fixya. Dont forget to rate!
8helpful
4answers
My Kindle (version 3) suddenly won't connect to my wireless network. I've re-entered our wireless passcode, but still doesn't work.
On a wifi connection when you see problems the cause will either be the device or the wifi router.
If you can try the kindle out on a different network this will tell you if it is the kindle or the network. If it connects then it not the kindle. It could be a setting or the router.
If it is a setting the two biggies are going to be something wrong with the security passcode or it isn't getting through the gateway out onto the internet. For settings you need to check things like using wep when it should be wpa or the wep key is 64bit when it needs to be 128 or in the wrong key location and so on.
When it can't get through the gateway that usually means your dhcp is wrong or you are using fixed ip. You can just set these numbers manually in the kindle.
The other usual suspect is that the router itself is beginning to fail. This usually shows up first as difficulty to connect and dropped connections or increasing errors. It will eventually fail. This is common and typical of all home grade wifi routers. They are good for about 18 months or so. If this is the case you might notice slow downs or dropped connections on other wifi devices. These units are not repairable so you just need to replace it.
Out of all the possibilities I would say your first choice would be the security settings and next would be the the router. Those are the two most common problems.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
