Re: Trying to hook up sound bar cant get it to work any...
Check the video Hope you will find it helpful.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
Can I suggest that you unplug all the cables from the sound bar to the TV and disconnect both units from the mains. Attached the sound bar cables to the TV and then reconnect both units to the mains. Switch them both on and try again.
what do you mean hooked up and then no sound, hooked up with dvd player in the tv and then no sound?. ok check the cable if no loose connection, replace if possible.if still doesn't work tried to hooked up in other component input in your tv unit just to ensure if the problem is with in the signal input board.
If you tried hooking each unit up one at a time without the box and they work either a setting on that box is wrong or there is a problem with the box.
