Microwave Ovens Logo
Cindy Haines Posted on Feb 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JUST STOP WORKING NO POWER. - SpaceMaker GE Microwave Ovens
John Berry
Level 2:
Habit-Forming:
New Friend:
  • Expert 128 Answers
  • Posted on Feb 26, 2016
John Berry
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
128
Questions
0
Helped
35885
Points
217
There is a fuse inside the unit you may check and see if that is it. If not then it will be the front panel. Hope this helps
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
1helpful
The stop and start buttons on my HMT t8656gb have stopped working. Can they be replaced or do I have to purchase a new one?
Good evening to you.
I hope the same thing is not happening to you that happened to me.
What happened was that I had the buttons had stopped working because of my impatience for the micro to work.
I thought I would give the micro a rest, disconnected the power and let the micro rest over night. Connected it then to the power and started it like i started it the way I did the first time.
I think it is worth the effort.
Kolbru
3helpful
4answers
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
1helpful
RCA Model RMW700 micorwave 1 yr old stopped working. No power, yet the outlet is live. No power to the display, no light inside, just dead. Stopped working when heating cold cup of coffee.
There is a fuse inside the cover of the microwave. You will need to remove the outer shell and follow the power cord you will see an inline fuse. This fuse can be purchased at any appliance parts house.
Hope this helped
Dave
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
R9H84B Sharp Microwave Convection from 6-6-1997, power stopped and turntable stopped. Light works and sounds like the power is working but nothing gets hot.
Is this the unit with the door that swings down like a conventional oven?? I think it is. This sounds like a door switch but could be a magnetron or cook relay on the control PCB.
1helpful
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
2answers
My microwave has stopped working and switched on suddenly!!
Sounds just like a bad door switch or door switch mount. Probably the upper one. Safety info, disassembly tips, and door switch test and replacement info are all available at our Web site. See http://tinyurl.com/yzjozk
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
