If I replace the screen is it likely the phone will work again? Or is the fact that my computer won't recognize that it's even plugged in mean its got bigger issues? Also,the phone was reset before it broke so it's not set up again yet with my itunes account. So not sure if there are ways to test functionality.
Can't be certain, but could be the impact that broke screen damaged a board or component under the screen. My daughter had a similar fatality - the 5's screen was badly cracked, but worked for a while until it finally failed to be recognized by computer. She hasn't sent it to me yet for testing, so I can't be certain but it doesn't sound good. You can try to follow a you tube video on a tear down to at least do a visual inspection.
SOURCE: iPhone does not get reset
put the phone in DFU mode.
hold the power and home buttons for 10secs then release the power button only leaving the home button pressed note u must be connected to itunes via usb and u will see a rec option ,press shit and clikc restore select the 152 mb 1.1.1 update ipsw file and the i phone will restore.
SOURCE: iPhone not charging, not recognized
You need to restore whit the last version of iTUNES and an ofiial firmware. Then apply jailbreak.
SOURCE: iTunes doesn't recognize iPhone SIM card
u pls jailbroke the iphone with redsn0w , then it will be
SOURCE: iphone wont turn on!!!
Hi slondon83,
I believe you will have to reflash your device, using the restore feature on iTunes and the CFU mode in you iPhone.
To restore your iPhone, you will have to enter to CFU mode:
1. turn off your phone, or wait it get turned off by itself.
2. press and hold the power button for exactly 3 seconds.
3. whithout leaving the power button, press the HOME button for another 10 seconds exactly.
4. after 10 seconds leave the power button but still, keep the HOME button pressed.
try all these steps, of course, while you iPhone is connected to your computer with the USB cable and the iTunes software is on.
you might be able to do it with this method too:
good luck!
SOURCE: Iphone 1.0.2 unlocked does not recognize sim card
had my phone unlocked and jail broken .....was updating it on itunes and now it wont read my sim card...what do i do!!!!!!
