Translate this page
de la calculatrice SHARP, veuillez prendre les ... Insert the new ribbon. 6. ..... AC adapters, ribbons, correction tapes, ink rollers, cables, printwheel, or paper.
Your best bet is to phone or send me an email with address. Edmonton Cash Register Co. Ltd carry a huge inventory of ribbons and ink rollers for most cash register in the market place. Your Royal 125 is a older machine and the ink roller is IR40. Please quote the #'s. If you have any other question please contact us. Have a nice day
Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
If printing is blurry even when the ink roller is in the proper position, replace the roller. Ink roller: Type EA-732R
WARNING APPLYING INK TO WORN INK ROLLER OR USE OF UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER.
1) Turn the power off. 2) Remove the printer cover. (Fig. 1) 3) Remove the ink roller by turning it counterclockwise and pulling it upward. (Fig. 2) 4) Install the new ink roller and press it in the correct position. Make sure that the ink roller is securely in place. (Fig. 3) 5) Put back the printer cover.
Ink roller: Type EA-772R WARNING: APPLYING INK TO WORN INK ROLLER OR USE OF UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER. 1) Set the power switch to OFF. 2) Remove the printer cover. (Fig. 1) 3) Hold the top of the ink roller and remove the roller by pulling it toward you and then upward. (Fig. 2) 4) Install the new ink roller in the correct position. Make sure that the roller is securely in place. (Fig. 3) 5) Put back the printer cover.
Replacing the Ink Roller 1. Press OFF. 2. Remove the printer compartment cover. 3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment. 4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place. 5. Replace the compartment cover. Warning Never refill or moisten the old ink roller. This can damage the printing mechanism and void the warranty.
Replace the toner cartridge with a brand new one. There's no such thing as refilling toner cartridges. When it's empty, the drum unit is finished and it should be replaced, not refilled. Remember that the drum unit is sensitive to light, and will also be damaged if exposed to a great amount of light over a perid.
If a new cartridge does not solve your problem, remove the cartridge and check out the charge roller. It's located in the upper part of the "cartridge-room". It's a grey roller. lower the front cover the get easy access to it.
If it looks nice and clean, just leave it. If it is dirty and smutsy, you should remove it and try to clean it with hot water. If it is damaged in any way, it should be replaced.
Still problems ?
Check out the fixing unit. Remove the fixing unit and look at the the big rollers that put out the paper. If they look nice, put the fixing unit back in. If they are burned and dirty, replace the fixing unit.
Wow, nice "solution," Printech. That is BS. There has to be a way to trick this printer into using refilled ink. If not, why would they sell refilled ink kits for this printer? Cut the **** and give us a SOLUTION. I refuse to pay $30 for a "certified Lexmark" cartridge when I can spend $15 for a refilled one.
1. Check the toner cartridge and be sure nothing is blocking the ink flow.
2. The drum cartrudge may also have something on it blocking the laser light from getting to it.
3. There may be something in the laser window blocking part of the light path.
4 Something in the scanner blocking the image.
5. A defective scanner, yes even if new.
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
