Cars & Trucks Logo
t
tanicesa wood Posted on Jan 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need code fo toyota car ratio Nhdtw57d - Toyota Cars & Trucks
Mikey
Level 3:
Top Expert:
  • Toyota Master 6,904 Answers
  • Posted on Jun 11, 2016
 Mikey
Toyota Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623663
Points
26106
For Toyota radio codes try this service: Car Radio Code Uxbridge London Gumtree
2002 Toyota Highlander P1135 A/F Sensor Bank 1 Sensor 1
The air-fuel ratio sensor is located in either the exhaust manifold or the front exhaust pipe. It measures the amount of air in your exhaust and uses that information to determine your current air-fuel ratio.
Best to you
Looking for manual for a 3AU Toyota engine
The best solution you'll get from books at www.reliable-store.com
These are books containing in fo on repair, service, troubleshooting , parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
2008 hilux diff ratio
need lots more information to determine exactly what the manufacturers ration would be
manual and auto have different ratios as do diesel against petrol have different diff ratios
go google and type in --www.vehicle mods.net.au and you will find a toyota hilux drive train gearing bible that covers the years 2005-2015 it explains everything including different tires and the effects on ratio readings
I found it by going google and typing in--toyota hilux diff ratios ---
1994 22re toyota code 25
25 Air-Fuel Ratio Lean
You need to test the intake manifold for a gasket leak.
Diff ratio. On a 1994 toyota 4 runner v6 petrol ??
4x4, 4 cyl, 4.10 ratio, ABS 4x4, 4 cyl, 4.10 ratio, w/o ABS
4x4, 4 cyl, 4.56 ratio, ABS 4x4, 4 cyl, 4.56 ratio, w/o ABS
4x2 (3.90 ratio), 2 wheel ABS 4x2 (3.90 ratio),
4 wheel ABS 4x4, 6 cyl, 2 wheel ABS, 4.30 ratio
4x4, 6 cyl, 2 wheel ABS, 4.56 ratio 4x4, 6 cyl, 2 wheel ABS, 4.88 ratio 4x4,
6 cyl, 4 wheel ABS, 4.30 ratio 4x4, 6 cyl, 4 wheel ABS, 4.56 ratio
4x4, 6 cyl, 4 wheel ABS, 4.88 ratio there are a few options. you will need to figure it out or look at the code panel in the truck. if you want to figure it out. you will need to remove the cover from that axle and count the two ring gears and then divide the numbers to get the gear ratio. for example if one is 40 and the other was 11. would be 3.72. so here is the trick to counting the gears. they are covered in oil so have a pan ready when you pull the cover. and use a marker or crayon and mark a tooth on the gear ring. then count the gears and you will know where to stop when you get back to your mark. the little gear will be harder since its in the back. you might have to turn the wheels and you will need it in neutral and jack the rear end up. as always use jack stands to prevent damage to you or the truck..
I have 1995 Toyota 4 runner and OBD 1 codes 25 and 26 light up my check enging light what do I need to do to fix this problem
Reading about air fuel ratio on this. It points to an O2 sensor replacement. Emission parts are often forgotten, Yet are extremely important to these trucks performance. Any car really.
1helpful
O2 malfunction P1135. Please what do i need to buy to replace ? Can I do this myself or will have to let an expert do it. i would be very grateful if you could tell me what EAXACTLY that I need to buy...
The P1135 code on your Toyota is Air fuel ratio sensor - heater circuit malfunction. Basically the problem there will be with the air/fuel ratio sensor (on other vehicles it is refered to as an O2 oxygen sensor), or the wiring/connectors leading to it. It could also be a problem with a fuse or relay on the heater circuit. Again, not a real difficult problem to solve.
just fixing the P1135 code will not cause the check engine light to stay off because there are other unrelated codes. If the code P1135 was causing the other problems then perhaps fixing that code would fix the others, but that's not the case here. The reality is you'll need to have all the problem areas looked at (IAT sensor, MAF sensor, Air/fuel ratio sensor) and repaired in order for your engine light to stay off. Normally if there are codes stored a vehicle cannot pass inspection. I would get a second opinion from another local mechanic as what you've been told may not be 100% correct.
Good luck.
2helpful
Error code P 1135. what part needs to be replaced?
P1135. Air/Fuel Sensor Heater Circuit Response. (Bank 1 Sensor 1).
Now, to specifically answer your question. I'm not familiar with the inspections in New Jersey, however just fixing the P1135 code will not cause the check engine light to stay off because there are other unrelated codes. If the code P1135 was causing the other problems then perhaps fixing that code would fix the others, but that's not the case here. The reality is you'll need to have all the problem areas looked at (IAT sensor, MAF sensor, Air/fuel ratio sensor) and repaired in order for your engine light to stay off. Normally if there are codes stored a vehicle cannot pass inspection. I would get a second opinion from another local mechanic as what you've been told may not be 100% correct.
Good luck.
Decifering the "build" codes on Toyota Tacoma
I would call the dealer parts dept. they should be able to tell you what you need to know. there may be a difference in gear ratio for each engine/ trans combination. A salvage yard may be able to help you , they should have a computer system showing what rear is compatible. there should be a code on the axle housing itself.
6helpful
Code p1135 what wrong help,toyota 2000,highlander
That code is specific to the Air-Fuel Ratio (A/F) Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1135 Trouble Area:
 Open or short in A/F sensor (bank 1, sensor 1)
 A/F sensor (bank 1, sensor 1) heater
 ECM __________________
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
