Mitsubishi WS-65511 65" Rear Projection Television Logo
Posted on Jul 14, 2009
I have model VS50609 and it will not power on.
TV will not come on when pushing the power button on the TV or the remote. Checked power source and remote batteries. Any Ideas?
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Jul 14, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
10807
Points
96
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
2answers
Ecco TV 32 D-LED it just stuck on USB Mode,the source button is not working and i don't have a remote.Help
If your Ecco TV 32 D-LED is stuck in USB mode and the source button is not working, and you don't have a remote, there are a few things you can try to resolve the issue:
  1. Power cycle the TV: Unplug the TV from the power source and leave it unplugged for a few minutes. Then, plug it back in and turn it on. This can sometimes reset the TV and resolve minor software glitches.
  2. Try using the buttons on the TV: Although you mentioned that the source button is not working, try pressing other buttons on the TV itself, such as the menu or volume buttons. Some TVs have different combinations of buttons that can act as a substitute for the source button. Refer to your TV's user manual if you're unsure about the button combinations.
  3. Check for a physical source button: Look closely at the TV's physical buttons to see if there is a dedicated source button or a button with an icon indicating input selection. Pressing this button should allow you to cycle through different input sources, including USB mode.
  4. Borrow a universal remote: If you don't have the original remote for your TV, try borrowing a universal remote from a friend or neighbor. Universal remotes can often be programmed to work with different TV models. Check the remote's instructions or manual on how to program it for your TV brand and model.
  5. Contact the manufacturer: If none of the above steps work, it's recommended to reach out to the manufacturer's customer support. They can provide you with specific information tailored to your TV model and help troubleshoot the issue further.
tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 • Televison & Video
Hi. I have a harwa 32 inch tv flat screen. It has a blank screen but the power light remains red and respond to the remote if i switch on and off. I tried to unplug for almost 24 hours and checked the...
Have you tried checking the source/input? On the remote push the source or input button and try changing your source- hdmi 1, hdmi 2, wherever you have your cables hooked up, and make sure that particular source is powered up. On the tv's we've had, the outside antenna source is either called "video" or "tv". A quick clue would be if you push the input button and the little menu doesn't even appear. I'd say the screen is dead!
2answers
How do I access input source on my seiki tv without remote
Without knowing the exact model it would be hard to know the format. In your case I've looked at one manual and where the power button is there is also one button for volume, one for channel and one for menu and source together (4 buttons total). Each button rocks up and down, so the menu button should be up and on that same button source (input source) should be down. Once inside source navigate with Channel button.
What channel on the hci tv can I view my dvd I hooked the red yellow and white jacks into the back of tv but cannot find a channel to view the dvd
You probably need to find a Source or Input button or menu item. Change the source from TV (if that is your current source) to A/V (or composite video). Depending on the model, there may be a source/input button on the TV. There will always be a sourc/input button on the original remote. If you are using a universal remote, you may need to try a different code to get the function to work.
On a few TVs, you can find this in one of the sub-menus. However not all TVs let you change the source in the Menu system.
I hope this helps. Please add a comment with the model of the HCI TV and whether you have the original remote or a universal remote to control the TV if you would like me to find the specific information for your TV.
(For example, the HCI RM22 III remote has the input button on the left side just below the power button.)
2helpful
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
1helpful
2answers
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
1helpful
Unit will not come on when pushing the power button on the TV or the remote. Checked power source and pushed reset button. Any Ideas?
yea this pictilar model kwon for this it is the vertical drive ic i recommend checkint it fist check fuses may fix ur problem impossible to geusse
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
