How to check your Transmission Fluid Level - YouTube
? 1:12
https://www.youtube.com/watch?v=zqwbRNQLfSI
Oct 14, 2010 - Uploaded by Robert Callahan
How to check for the proper transmission fluid level. ... Uploaded on Oct 14, 2010. How to check for the proper transmission fluid level ... Then, turn the car off and locate your transmission fluiddipstick. Different cars have ...Missing: epic's
sv6 no transmission dipstick??? :S - Just Commodores
forums.justcommodores.com.au/...holden.../127200-sv6-no-transmission...
Feb 5, 2010 - 5 posts - 2 authors
... ive had my sv6 for about 4-5 months now, and i never realised it doesnt have adipstick to check transmission fluid wtf?? my 89' vn has one. ... Just Commodores -Holden Commodore Discussion Forum ... 05-02-2010, 12:07 PM #1 ... As mentioned the 5L40 box in the SV6 & Calais is a sealed unit, so no trans dipstick.
Auto transmission oil DIPSTICK
Dec 23, 2011
Checking 6 Speed Transmission Fluid - Just Commodores
Jun 9, 2011
Too much tranni fluid in my Transmission - Just ...
Mar 25, 2011
4hdd 4L60E - death rattle?
Nov 23, 2008
More results from forums.justcommodores.com.au
Missing: epic's
SOURCE: cant find transmission dip stick 1999 isuzu tropper
The 4L30E transmission is a "sealed" unit and as such does not have a
dipstick. The only way to check your fluid level is to use the "higher"
of the two drain holes on the bottom of the pan. You *must* do this
while the engine is hot and running, otherwise all the fluid will have
drained to the pan and will come out of the top hole all over you.When
hot, the fluid should come up to the top hole. Stick a finger in, if
you can't feel fluid, use a syphon or hand pump to shoot some up into
it. I would strongly suggest dropping the pan and
replacing the filter if you have over 100k miles. DO NOT have
this trans flushed at a shop as the small galleries are prone to
jamming with the gunk the flush will free up, and will cause the trans
to fail.
Benjamin
SOURCE: I can't locate the transmission fluid dip stick for 2003 Grandam
Your transmission is sealed and has no dip stick, checking the fluid level properly involves using a factory scan tool.
SOURCE: where is the transmission dip stick?
THE DIPSTICK WAS ELIMINATED AND TUBE WAS CAPPED OFF..DEALER HAS SERVICE DIPSTICK TO CHECK FLUID LEVEL..A TRANS SERVICE SHOP MAY ALSO HAVE THIS TOOL
SOURCE: Where's my dip stick?
theres no dip stick ,there are to plugs on trany one on the bottom to drain and one on the side,remove the side one oil is full when it starts to flow out,but caution dont star removing bolts unless your sure could cause trany damage on some tranys,go to a oil and lube shop have them lift truck and check takes 5 to 10 minutes,good luck.
Testimonial: "thank you, this confirms information I was finding elsewhere."
