Cars & Trucks Logo
L
Louie Caban Posted on Nov 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2007 toyota yaris shift lever is stuck on park, what could be the problem?
Claude Kayser
Level 3:
Top Expert:
  • Toyota Master 9,098 Answers
  • Posted on Nov 05, 2015
Claude Kayser
Toyota Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067759
Points
28436
Shifter stuck in the Park position - YouTube
? 3:17
www.youtube.com/watch?v=-myhP6tRv4U
Jan 2, 2012 - Uploaded by iworkforbudlight
Short video on how to get your shifter out of park when it's stuck. This is for ... I'm assuming that's a Toyota ...
Shifting lever stuck in park - 2004 Toyota Camry - RepairPal
repairpal.com > Questions > Toyota > Camry > 2004 Toyota Camry
Aug 21, 2014 - my shifter got stuck in park,I read the book and read to take the little cover off by the shifter and push the botton to release the shifter. it worked fine ...Shifting lever stuck in park on 2004 Toyota Camry .... 2007 Toyota Camry ...Missing: yaris
2answers
How do i manually unlock gear shifter
If you cannot shift out of PARK (P), ease the pressure on the shift lever. Push the shift lever all the way into PARK (P) as you maintain brake application. Then move the shift lever into the gear you want. If you are still having a problem shifting, then have your vehicle serviced soon.
Engine shutdown when shifting to neutral
stalls
all time first that, usually its other way.
going from load to no load, should never fail.
so is the power 12vdc dropping as you move the lever
turn lots of things on, lamps, park , radio. etc.
is there a lost of 12v power at the stall.?
The yaris is automatic transmission(the lever is not select properly,the car is not moved the oil is overfiow
i cant read that.
1: i can't move shift lever, from park to drive?
2: the car will not move, that is i can not drive car.
3: the oil from (what) is overflowing. what oil, landing where?
the #3 is the most perplexing,
can you crank engine?
does engine start?
if engine oil is on the drive way, do not start car. or risk burning up engine,, (brown oil, not stink to high heaven)
if A/T (ATF) its pink oil, if on drive way, then the tranny is breached.
do not drive or the tranny will burn up.
to sure #1 , read the operators guide.
you start the engine,
apply the foot brake and the shifter lock ,releases.
2008 honda sticks in park
It can be issue with gears or problem with transmission and needs to be rebuilt. Also get the ****** fluid checked. If it's low, then such problems occurs.
To troubleshoot these types of issues, check the actual solved problems with these types of issues.
There are solved help links provided below: -------
Click the link below and go through the details and diagrams to troubleshoot the problem: -----
2003 Lexus RX300: Transmission Fluid Burnt Brown and not Shift to reverse?
http://whatisbyme.blogspot.in/2012/05/2003-lexus-rx300-transmission-fluid.html
2007 Chrysler 300: Transmission Stuck in Park?
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
1996 Toyota Corolla: Transmission Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
CV AXLE stuck in Transmission?
http://technoanswers.blogspot.in/2012/04/cv-axle-stuck-in-transmission.html
Transmission in reverse, acts like it's in neutral? http://schematicsdiagram.blogspot.in/2012/04/transmission-in-reverse-acts-like-its.html
Delayed shift and harsh Shifting?
http://schematicsdiagram.blogspot.in/2012/04/delayed-shift-and-harsh-shifting.html
Dodge neon wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Dodge Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Dodge manual transmission will not go in reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
1998 Dodge Ram: Not Shift To Reverse? http://schematicsdiagram.blogspot.in/2012/06/1998-dodge-ram-not-shift-to-reverse.html
Transmission leak on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/transmission-leak-on-toyota.html
Automatic transmission, with no reverse?
http://howtobyme.blogspot.in/2012/02/automatic-transmission-with-no-reverse.html
No Movement When Transmission is Shifted to Drive or Third?
http://schematicsdiagram.blogspot.in/2012/03/no-movement-when-transmission-is.html
While going in reverse mode Fuse number 27 blows on Ford Ranger?
http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
These will help.
Thanks.
The shifter needs to be inspected. If The shifter assembly is got misaligned, it has to be open and realign.
There are many other possibilities.
Also i suggest you to refer these gear shift issues, which are mostly noticed. These are direct links with appropriate solutions to the specific problems of gear ****.
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html --------- 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html ---------- 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html --------- Car will not move when in gear? http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ----------- Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ---------- Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ---------- Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
------- 2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html -------- 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html -------- Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html --------- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
----------- Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
-------- Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
------------ No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html ------- Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html --------- 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html -------- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
---------- 1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html ------ Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
-------- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
-------- Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
---------- 2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html ---------- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
-------- Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--------- Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html --------- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------------ 2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
2002 acura tl 3,2 stuck in park
It can be shift mechanism issue or its faulty worn out gears.On some cases like these its also seen that problem relates to transmission rebuilt.But that is rare,if these problem is suddenly occurred without any previous problem.To troubleshoot these issue,i suggest you to refer the solved helplinks with appropriate solutions.-----------Click the link below:-----
Thanks.
2answers
Needing to troubleshoot transmission problems for my 2001 pontiac grand prix
It can be issue with transmission,most probably it needs to be rebuilt.
GEAR SHIFT ISSUES
2007 Hyundai Santa Fe: Will not Shift out of Park Mode? http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These will help.
Thanks.
What is shift lock in vitz 2007
Shift lock control unit is the transmission control switch which detects the shift lever in S
2008 yaris is stuck in park. how do I get it to shift into drive?
put your key into the slot next to the shifter and turn if necessary. put key into ignition put your foot on the brake and shift out of park. goodluck
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
