Akai PDP42Z5TA 42 in. Plasma Television Logo
Lesley A Dourbet Posted on Oct 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset tv to factory settings...?
Does anyone know how i can reset this tv without the original remote and with a screen that will not show menu or anything else for that matter?
Level 3:
Top Expert:
  • Akai Master 76,851 Answers
  • Posted on Oct 11, 2015
Akai Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008156
Points
237762
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
TV Sharp LC-40LE830U. My front panel ys disabled and my remote control don't work. I can power on/off only. How can I enable my front panel without use remote control? or reset factory settings?
If both your front panel and remote control are disabled, the best option would be to perform a factory reset to restore the TV to its original settings.
To reset the Sharp LC-40LE830U to factory settings:
  1. Unplug the TV from the power outlet and wait for at least 60 seconds.
  2. Press and hold the power button on the TV for 5 seconds while the TV is still unplugged.
  3. Plug the TV back in and turn it on using the power button on the TV itself.
  4. Once the TV is turned on, press and hold the "input" and "volume down" buttons on the TV simultaneously for 5 seconds.
  5. The TV will then enter the service mode menu.
  6. Press the "menu" button on the remote control to navigate through the menu and select "option."
  7. Select "factory reset" from the options menu and follow the on-screen instructions to complete the reset.
Note: The factory reset will erase all custom settings, including parental controls, picture, and audio settings.
How do I reset my AIm 32tv locked no remot
To reset your AIm 32TV without a remote, you will need to follow these steps:
  1. Locate the "Menu" button on the TV: The button is usually located on the side or at the bottom of the TV.
  2. Press and hold the "Menu" button: Press and hold the button for about 10 seconds or until the TV turns off.
  3. Turn the TV back on: Press the "Menu" button again to turn the TV back on.
  4. Look for the "Factory Reset" option: Once the TV turns on, navigate to the "Settings" or "System" menu and look for the "Factory Reset" option.
  5. Perform the factory reset: Select the "Factory Reset" option and follow the prompts to reset the TV to its original settings.
Note that these steps may vary depending on the specific model of your AIm 32TV. It's also important to check the user manual for the correct steps.
If you are unable to find the factory reset option, or if the TV is locked, it may be best to consult the manufacturer or an authorized TV repair center for further assistance.
2answers
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Element tv eleft422
Without its remote control, you can't do a system reset to this set.
Try a Hard Reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
If a hard reset do not help, you should buy its original remote control from its authorized service center.
How do I reset the 52" TV to original settings. Screen is on Widescreen permanently
Could you please post exact model of your sharp tv. however i will give you this generic solution. In order to do this, you'll need to have your remote handy. You cannot reset the television using the control panel.
  • Turn your Sharp television on. Press the "Menu" button on your remote control. Press the "Right" arrow until you see "Setup."
  • 2
    Press the "Down" arrow until you see "Reset" displayed under the Setup menu. Press "Enter."
  • 3
    Type your secret four-digit code using the remote keypad. If you do not know it, you'll need to reset it by following the process in the section "Resetting the Parental Control Password." After you type in the code, "Reset to Factory Preset Values" will appear on the screen.
  • 4
    Press the "Right" arrow to select "Yes" then press "Enter." The screen will show "Now TV Will Restart." Press the "Right" arrow then press "Enter." Wait for the television to reset and revert to the factory default settings.
  • 0helpful
    Magnavox tv not responding to remotes
    I came accross this question, because I've been looking for the remote code for my cable remote. I had originally put the TV remote somewhere in a box when I was moving years ago, Since my cable remote changes the channel, I've been doing the same as you all this time. Therefore, I totally understand your frustration on trying to understanding how to navigate within the menu: It's not what you would think would be a standard or logical way....
    Anyway, in my research, I did come accross the TV manual, and I found the instruction on how to reset the TV. I tried the steps, and THEY"RE STILL confusing, so I've added my own hints....hope this helps:
    Your TV can be reset to the factory settings in case you forget your Smart Lock password, or want to change the picture, sound, or features settings.
    1 Press the MENU button on the remote control to see the onscreen menu.
    In the left panel, you will see four icons (from top to bottom)
    • TV INSTALL (a tv)
    • PICTURE (icon of film)
    • SOUND (a piano)
    • FEATURES (icon of pliers and a hammer)
    When the Menu screen is showing the left panel as highlighted light grey, the Chanel buttons have Page up/Page down Functionality
    2 Press the the (CH UP) or_(CH DN) buttons to highlight the FEATURES menu.
    Navigate to the FEAUTRES menu (icon of pliers and a hammer - bottom of left panel) and you should make sure it is highlighted in blue
    3 Press the (VOL+) button to enter into the FEATURES menu.
    The right panel should now be highlighted in a light grey
    4 Press the (CH UP) or (CH DN) buttons to highlight the FACTORY SETTINGS control.
    This will select items in the right panel, FACTORY SETTINGS in on the bottom
    5 Press the the _(VOL+) or _(VOL-) buttons to reset the TV to the original factory settings.
    6 Press the MENU button repeatedly to clear the menu from the screen.
    The entire manual is found at this link: http://www.m4c.magnavox.com/files/1/15mf200v_37/15mf200v_37_dfu_aen.pdf
    BTW, of any one know how I can program or get an RCN remote to use on this TV, please let me know!!!!
    Reset older analog tv
    Without the original remote, sorry none. You could try pressing on any of the buttons or a combination while plugging in the unit but that is no guarantee it will reset (fully). With your indulgence, I took the liberty of checking your other posts here and here. It would seem that your original concern is that although the TV would appear to be switching to the lower channels (Ch 2-6), the TV programs on those channels would not be displayed. If yes, then I am inclined to think that there is a hardware fault internal to the TV. This would be the tuner block. The reset, even if successful, would not correct this error.
    Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    2answers
    PX- rc1
    Basically all it takes to restore the TV to factory setting is to unplug the TV from power and all connecting cables for about 3-5 hours (depending upon your model). This is called a Hard Reset and should restore the TV back to factory defaults.
    11helpful
    2answers
    Can't shut off closed caption
    I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
    Top Akai Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
    Accurate TV Repair...
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
