20 Most Recent Element Electronics FLX3210 32 in. LCD TV Questions & Answers
Without its remote control, you can't do a system reset to this set.
Try a Hard Reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If a hard reset do not help, you should buy its original remote control from its authorized service center.
Element... | Answered on Feb 17, 2018
it could be the t-con board going. or the screen connector ribbon is lose. or even just the connection cable to the t-con board. if you push gently around the edge of the screen if the pitcher gets better or worse then its the screen connections. sometimes can be fixed with cracking the cable or slightly heating the area and packing, but this is with the led screen panel out. but would think its more a t-con board filing.
Element... | Answered on Feb 13, 2018
Antenna has no bearing on whether the TV will start or not that only provides the singan for the picture .
Element... | Answered on Aug 11, 2016
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Element... | Answered on Mar 29, 2016
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Element... | Answered on Feb 27, 2016
Main system control memory IC fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Element... | Answered on Jan 20, 2016
Try a different input for reception
Element... | Answered on Nov 17, 2015
blown caps in power supply they will be puffed up on top easy fix
Element... | Answered on Oct 08, 2015
Maybe some clue in this manual?
Element FLX 3210 User Manual
Element... | Answered on Jun 12, 2015
you will need the remote that came with the tv
in the menu it has limited control of colors an color temp.
Element... | Answered on May 11, 2015
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Element... | Answered on May 05, 2015
Element Electronics FLX3210 32 in. LCD TV Logo
264 questions posted
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Electronics Televison & Video
Most Popular Question
power light element tv not light up when
  • Televison & Video
