Somewhere, the route water is supposed to take during the defrost cycle is clogged, or the drip pan has so much dust the defrost water overflows. Or possibly the end of the drip tube has been knocked out of line and the water doesn't get into the pan. You probably need to at least clean all the dust and dirt from the bottom -- just doing that might solve it.
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may
be stopped up with ice at the upper end because it drains too slow because it's
stopped up at the lower end in the evaporator pan under the unit at the floor.
It can get dust and mold in it. Once you get the ice out at the top a little
pressure with a turkey baster will
usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. .
The drain should be located below the evaporator coils on the lower back of the
freezer.
