Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
How do you know that it's the problem? Do you hear the relays come on? Does your tv blink? How many blinks? That is a vital part in diagnosing a panasonic tv.
Power supply issue. Find a replacement on shopjimmy, ebay or encompass parts. Unplug the tv over night and then open the tv. Then replace the old power supply with the new one. That simple!
hi you will need first to isolate where the problem might be so try to plug other unit or device in your power surge like a dvd player. if it is work your lcd tv have problem now how are you going to fix your tv, use a philip screw driver and open the back cover to gain access the internal part. since doesn't turn on check the power supply first which is the main source of supply of all the board. replace blown fuse and other defective part. bulged capacitor will not work good replace it use the panasonic brand atleast 105c ratings it is effective. thanks hope will help you to fix the problem.
I am unsure as to "where to start looking" means? Do you mean parts to fix it or new TV's?
If you are looking to fix it, you will end up spending a lot more than you prolly want. The surge could have blown a board, Power Supply, fuse, capacitor, transformer or a combination of them all. These TV's are only 27" and if you look on government websites you will see they start the bidding around $5 for the whole TV. If you are looking to upgrade I would suggest balancing a budget that works for you especially with the economic issues going on. 1080p is the latest being talked about, but that doesn't mean it will work for you. I went to Walmart and spend $600 on a Visio HDTV 1080i and I have not had a problem yet (knock on wood). I would not suggest buying a Panasonic HDTV but that is my personal opinion - the majority of issues I have resolved at my full time job came from Panasonic Projection TV's and HDTV. At the same time they were able to shoot out one of first 103" TV's but that just means some tech will have a bigger TV to fix in the future - LOL..
