i have a yellow stain on screen of a panasonic pt-43lc14 it wont go away. it does not seem to be...
(More)
i have a yellow stain on screen of a panasonic pt-43lc14 it wont go away. it does not seem to be getting bigger.about size of basket ball
heard a clunking noise and the tv turned off and wont turn back on. not even thepower light comes...
(More)
heard a clunking noise and the tv turned off and wont turn back on. not even thepower light comes on...just blank
cant find right code for tv i have a panasonic hdtv tried codes that was given on...
(More)
cant find right code for tv i have a panasonic hdtv tried codes that was given on instructions.I need tech. support for my problem
handset displays "no link to base" battery shows full charge, but losses it's charge...
(More)
HANDSET DISPLAYS "NO LINK TO BASE" BATTERY SHOWS FULL CHARGE, BUT LOSSES IT'S CHARGE WITHIN A FEW HOURS
works for a few hours and shut down by itself and starts flashing green light and turns on by...
(More)
works for a few hours and shut down by itself and starts flashing green light and turns on by itself. I'm looking for the fan but cant find it. assuming the bulb is overheating and not getting enough cool air. The fan might needs some cleaning. Please help about the location of the fan.
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
