SOURCE: headset stopped connecting
ya it happened to me once ...press the pick up button and hold for 4-5 seconds till the blue light lights up then unfold it and then search
SOURCE: Connection failed
Read the "force connect" solution below... I was having the same problem and it worked for my blackberry. Good Luck!
SOURCE: CABLE & WIRELESS CWBTH160
To initiate pairing, put the devices within 0.5m of eachother
Make sure phone / pc bluetooth is on and discoverable
Make surea headset is fully charged
Pairing is then complete.
Note: Headset pairing mode will time out after 5 mins.
Note: Multi-pairing.
It is possible to pair up to two phones with the headset - the most recently paired phone becomes the "primary "phone... only one phone can be connected at a time --> this function only works in Hands-Free profile. If both phones are in range, then the headset will connect to the "primary" phone first.
SOURCE: Hi. Can my SBH500 BT Headset pair/connect to a PC?
Make sure the headset is put in pairing mode, to do this, turn the headset off, hold the phone button(big silver round one on the right speaker), then turn the headset on. Hold the button until the blue light goes solid. At this point, your computer should be able to detect it. Be aware, though, that support for bluetooth audio on computers is weak at best.
SOURCE: Insignia NS-BTHDP ok with phone, pairs with PC but can't connect
Make sure the headphones are set as "default" under Control Panel>Hardware and Sound>Sound>Manage Audio Devices - same for microphone if you're using it for online speech.
Were you able to get these to work? I have 3 that I got at a garage sale thinking they were bluetooth. They didn't come with a transmitter. Where can I get one?
