Question about iLive IHB603B Micro Bluetooth Stereo System with CD Player & AM/FM Rad
How can I get my player to connest to my bluetooth headphones have tried several times no luck
Was able to connect headphones to my Kindle but not working with the Ilive
Posted by Pamela Allen on
Ryan Jentzsch
  • 4 Answers
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).
Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on.
Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES.
You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.
HTH
Posted on Aug 20, 2014
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • iLive Master
  • 1,001 Answers
Bluetooth Headphones V3.0 Handsfree Stereo Wireless Headset with Microphone earbuds for Apple and Samsung LG Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless...
Posted on Jan 11, 2017
Wireless headphone connection on Samsung UN40H6203AF
Are the headphones regular wireless (with a transmitter, sometimes called base or dock) or are they Bluetooth headphones ?
Jan 01, 2015 | Audio Players & Recorders
Headphone jack on kindle fire doesnt work
If the sound works on your Kindle Fire's speakers and will not cut off and reroute sound to headphones when you plug them in to the headphone jack port on the side of the Kindle. Try the following:
If you have a set of blu tooth headphones then enable blu tooth connection to a source of sound like, You Tube, Spotify iTunes etc. You will be able to hear sound on your blu tooth headphones this way. Turn of the blu tooth headphones, then try plugging in your regular wired headphones into the Kindle and reconnection should be achieved.
Jul 07, 2013 | Tablets & eReaders
CANNOTE GET RADIO MUSIC NO SOUND
i've just finished repairing one of these Model 88 cd, from Cambridge sound. It also had no audio. I found cracked solder connections on the audio amplifier IC on the amplifier board as well as an inremittent headphone jack on the front of the radio. Try it with headphones, if you get dound try to clean the jack with isopropyl alcohol. a couple of drops inside the jack then insert the headphone connector several times to move the relay inside. Good luck. took me about two hours to resolve this with limited information available.
Sep 28, 2012 | Cambridge Soundworks 88CD CD Player
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
May 28, 2011 | Audio Players & Recorders
No music playing in headphones
Hello.
Try to adjust the headphone.
Check if it is connected properly.
If it still doesn't work, try to check the headphone on other devices.
If the headphone is working on other devices, your MP3 headphone jack has some problem.
But if the headphone is not working on other devices, you should get new headphone or you can try other headphone (besides your current one) on your MP3.
hope it helps.
Jun 09, 2010 | Coby MP-610 MP3 Player
Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Mar 11, 2009 | Jabra BT3030 Wireless Headset
Bluetooth not picking up mp3
@psychurmine you may need to go into the settings of the actual music player application on your phone and tell it to output to headphones.
@ejr420hotora it could be several problems. Did you have it working at one point or is this your first time installing it? Is this your first bluetooth device or do you have others?
Feb 12, 2009 | Insignia Bluetooth Wireless Headphones...
BLUETOOTH
Hello dmydeuce,
The setup you describe is possible, however you will want to make sure that your MP3 player, phone and headphones support both A2DP (Advanced Audio Distribution Profile) and also AVRCP (Audio/Video Remote Control Profile) protocols. Additionally in order to answer incoming phonecalls the headphones will need to have a built-in microphone. Check the documentation on your products.
Best Regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Audio Players & Recorders
iLive IHB603B Micro Bluetooth Stereo System with CD Player & AM/FM Rad Logo
209 people viewed this question
Top iLive Audio Players & Recorders Experts
Marvin
Marvin
Dennis
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
