Just upside the laptop...at the bottom you will see th model number near to the serial number You can try the below link..go there enter the part number and serial number to get the detials of the product.
You need to reset the contents of the flash eeprom that stores values like the password, serial number, MAC address and OEM numbers. This can often be acheived by removing and replacing the CMOS battery, which is (usually) located on the motherboard. You may have to disassemble the laptop to get at it.
I checked on the toshiba website. The model name is Portege and the model number is 3500. There are only 2 models of this laptop the other one has the model number 3505.
Hi, go to the link below, imput your serial number to down load your drivers.<br>http://uk.computers.toshiba-europe.com/innovation/generic/SUPPORT_PORTAL/<br><br>
ecommended Windows 7 Installation Method SelectionToshiba
provides support for installing Windows 7 on laptops built since 2007.
Depending on your model, Toshiba recommends using one of the following
software tools as part of the Windows 7 installation process, to
support ongoing use of Toshiba provided features and functionality:
Toshiba Upgrade Assistant for Windows 7, for upgrading from Windows Vista to Windows 7 on laptops made in 2009
Toshiba
Software Installer for Windows 7, for performing a Custom Installation
of Windows 7 ("clean install") on laptops made 2007-2009
Find
your laptop's serial number on a sticker on the bottom of the laptop,
note the second character in that serial number, then click on the
matching link in the list below for instructions on Toshiba's
recommended Windows 7 installation method for your model. For all laptops made since January 1, 2007* When upgrading from Windows Vista (not a Custom or "clean" Install)
if the second character of your laptop's serial number is 7 or 8, click here.
if the second character of your laptop's serial number is 9, click here.
When upgrading from Windows XP, or doing a Custom Install ("clean install") from any operating system
if the second character of your laptop's serial number is 7, 8, or 9, click here.
if the second character of your laptop's serial number is not 7, 8, or 9 then it was manufactured prior to 2007.*
* Installation of Windows 7 is not supported by Toshiba for laptops made prior to 2007.
you will have to get in touch with toshiba themselfs with the serial numbers from the back of your laptop. there should help you from there, I dont think there do have a default password, but do get in touch with toshiba. or read your namanual what came with the laptop.
Normally serial numbers are only found on the manufacturer tag on the laptop or the tag on the box it came in. Take a photo of the laptop or cut/copy the tag from the box. Suggest you keep a copy of all submissions in case they lose it.
