Sometimes when either a propane or natural gas system has air in the lines they will not work. To be safe I would recommend you call the Raypak technical support line at 800-947-2975 or800-627-2975 and they should be able to help you figure this issue out. I hope this helps.
I would contact Raypak technical service and they may be able to help you correct the issue over the phone. This is even more likely since the heater is new. I hope this helps.
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com BD1 Board failure EEP Microprocessor error FAN Blower pressure failure FFL Flame sensing when pilot and gas valves are closed GVC Gas valve closed GVO Gas valve open HL1 High limit switch #1 open HL2 High limit switch #2 open IGN Ignition failure ILO Ignition lockout - Propane units only PRS Water pressure switch open ROL Heat roll-out safety switch open SNS Sensor failure, Water temp. below 36°F or above 110°F VNT Vent switch open
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board.
http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok
To confirm the fault in PC board.
Check for exact 24 volts on PC board.
One yellow and One Blue wire.
For checking transformer check
120/240 volt to transformer(time clock circuit breaker wire connections).
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
