Question about Raypak Pool & Spa
Have a Raypak RP 2100 Millivolt Plus pool heater. After turning on the pilot light I turn the heater switch to on and turn up the temperature. Once the dial gets past the current temp where it clicks it makes a noise at the gas valve and shuts down the pilot.
5 Related Answers
Anonymous
  • 195 Answers
SOURCE: lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Posted on Mar 30, 2009
Anonymous
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
Heath Moyer
  • 767 Answers
SOURCE: I have a Raypac digital
Hello my name is Heath it will be my pleasure to assist you. Find the rollout switch and on the back there is a small red button if you push the button in it will reset the switch. The rollout is usually located near the burner section of the heater.I will attach a picture of a rollout switch which shows the small red button.11c0d2e.jpg
Posted on Oct 25, 2010
Nicolo Carlo Parazo
  • 2187 Answers
SOURCE: Hi, The pilot won't light
I am thinking it could be the relay. The relay directs the power to the device. In most devices it is the one that makes the 'clicking' sound.
Posted on Apr 10, 2011
kebah
Angel Joseph Jr.
  • 684 Answers
SOURCE: We have a Raypak heater (model P-R335A-EN) that
Check the igniter on pilot assembly for soot build up, this igniter also acts as sensor for pilot flame proving, it will detect less heat from pilot flame if there is soot formed on and will not fire up burners. Check also the location of the temperature probe that you have replaced, it may not have sensed correct water temperature. If you think that hi limit is bad, you have to replace it right away because hi limits on all gas fired equipments is the safety device of the system in terms of preventing over heating which could result damage on property or life.
Posted on May 26, 2011
I have an RP 2100 pool heater and the minimum temperature set point is 65 degrees. Every time the pool/spa temp falls below 65 degrees, the heater automatically turns on. How can I either disable this...
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Nov 27, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypack RP 2100 The heater doesn't turn on, is there a reset
the electronic heater has an on off switch on the side on older models on the front on newer.the power goes to a transformer this in turn is converted to low power .
Jul 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool & Spa Logo
176 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Marvin
Marvin
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
