1997 Chevrolet S-10 Pickup Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There are 4 pins on my maruti wiper motor. how do i run it using a 12v battery?(connections?)
kirtec auto
Level 3:
President:
  • Chevrolet Master 1,348 Answers
  • Posted on Jul 11, 2009
kirtec auto
Chevrolet Master
Level 3:
President:
Answers
1348
Questions
0
Helped
596636
Points
4360
One is a ground and the other 3 are speeds. all you need to do is put a 50 watt bulb in series with the 12 volt line,so that if you short to ground,all it does is light the bulb,not burn wiring etc.a car battery can put out a couple hundred amps or more.a 50 watt bulb limits the current to 5 amps,and it is enough to run the wiper motor...cheers
ed
1helpful
2005 crown vic. p71v 1st the fluid stopped and the wipers would'nt shut off, now 1 day later no fluid still and the wipers stop working completely, please help me
Principles of Operation
The windshield wiper motor receive inputs from the following:
  • multifunction switch
  • lighting control module (LCM)
  • ignition switch
  • battery junction box (BJB)
  • central junction box (CJB)
The following components are integrated into the windshield wiper motor:
  • windshield wiper motor module
  • high/low speed relay
  • run/park sensor (Hall effect)
  • washer pump relay
High Speed Windshield Wipers
High speed is activated when the multifunction switch supplies ground to the windshield wiper motor module inputs. The windshield wiper motor module then supplies ground to the run/park sensor and high/low relay coil, activating the relay with voltage supplied from the ignition switch (RUN/ACC) through the central junction box (CJB). When the windshield wiper motor module receives voltage from the run/park sensor, it removes ground from the run/park sensor, deactivating it. The windshield wiper motor continues to operate from voltage connected through the run/park sensor until the Hall effect senses the magnet in the motor. When the Hall effect senses the magnet in motor the windshield wiper motor returns to the park position, the internal run/park sensor grounds the windshield wiper motor module input and the windshield wiper motor module removes ground from the windshield wiper high/low relay coil, deactivating the high/low relay and windshield wiper motor. The windshield wiper motor module continues to cycle the windshield wipers until the inputs from the multifunction switch are changed from the high speed position.
Low Speed Windshield Wipers
Low speed is activated when the multifunction switch supplies a specific ground to the speed inputs of the windshield wiper motor module. The windshield wiper motor module then supplies ground to only the windshield wiper run/park relay coil, activating it. When the windshield wiper run/park relay is activated, the deactivated windshield high/low relay connects voltage to the windshield wiper motor low input activating the wiper motor. The windshield wiper motor module continues to operate the windshield wiper motor in the same manner as in high speed, but in low speed with the wiper motor connected to the low speed input.
Intermittent Speed Windshield Wipers
The intermittent wiper speed is activated with grounds controlled by the multifunction switch inputs to the windshield wiper motor module. The windshield wiper motor module then activates the windshield wiper run/park relay coil and switches voltage through the windshield wiper high/low relay. The high/low relay remains deactivated, supplying the voltage to the wiper motor low speed input and activates the windshield wiper motor. When the windshield wiper motor module receives the grounded input, the motor continues to operate until Hall effect sensors senses the wiper motors magnet, which turns off the run/park sensor output to the windshield wiper run/park software, deactivating the relay and disconnecting voltage to the wiper motor. The windshield wipers remain parked until the windshield wiper motor module completes a time-out and then repeats the intermittent windshield wiper cycle.
Washer System
The windshield washer is activated by the internal wiper motor module when it receives a ground from the multifunction switch between the washer input. Dependent on the correct ground, the internal wiper motor modules activates the windshield washer relay (internal) by grounding the respective relay coil. When the relay is activated, it connects voltage to the washer pump while the washer level switch provides ground to the washer pump.
Default Mode
The windshield wiper motor defaults to this mode when the run/park sensor does not sense the hall effect magnet inside wiper motor. This can be caused by obstruction of the windshield wipers or a binding linkage. The windshield wiper motor will continue to operate in a high/low speed condition for a period of 60 seconds.
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The wipers are inoperative
  • Multifunction switch
  • Circuitry
  • Ignition switch
  • Windshield wiper motor
  • Go To Pinpoint Test A .
Do you know how to test automotive electrical circuits using a factory diagnostic test procedure flow chart ?
PINPOINT TEST A: THE WIPERS ARE INOPERATIVE Test Step Result / Action to Take A1 CHECK CIRCUITS 65 (DG) AND 2025 (RD/YE) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Windshield Wiper Motor C125.
  • Key in ON position.
  • Measure the voltage between windshield wiper C125 pin 5, circuit 2025 (RD/YE), harness side and ground; and between windshield wiper motor C125 pin 8, circuit 65 (DG), harness side and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to A2 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A2 CHECK CIRCUITS 57 (BK) AND 676 (PK/OG) FOR OPENS
  • Measure the resistance between windshield wiper C125 pin 6, circuit 57 (BK), harness side and ground; and between windshield wiper motor C125 pin 3, circuit 676 (PK/OG), harness side and ground.
  • Are the resistances less than 5 ohms?
Yes
GO to A3 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A3 CHECK THE MULTIFUNCTION SWITCH
  • Disconnect: Multifunction Switch C202b.
  • Carry out the multifunction switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Does the multifunction switch pass the component test?
Yes
GO to A4 .
No
INSTALL a new multifunction switch. REFER to Section 211-05 . A4 CHECK CIRCUIT 57 (BK) FOR AN OPEN
  • Measure the resistance between C202b pin 5, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to A5 .
No
REPAIR the circuit. TEST the system for normal operation. A5 CHECK CIRCUITS 56 (DB/OG), 58 (WH), 61 (YE/RD), AND 63 (RD) FOR OPENS
  • Using the following table, measure the resistance between the multifunction switch C202b harness side and the windshield wiper motor C125 harness side:
    Multifunction Switch C202b Windshield Wiper Motor C125 pin 6, circuit 56 (DB/OG) pin 10, circuit 56 (DB/OG) pin 3, circuit 58 (WH) pin 11, circuit 58 (WH) pin 1, circuit 61 (YE/RD) pin 1, circuit 61 (YE/RD) pin 4, circuit 63 (RD) pin 9, circuit 63 (RD)
Yes
GO to A6 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A6 CHECK FOR CORRECT WIPER MOTOR OPERATION
  • Disconnect all wiper motor connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all wiper motor connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
GO to A7 .
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. TEST the system for normal operation. A7 CHECK THE WINDSHIELD WIPER MOTOR
  • Carry out the windshield wiper motor component test as outlined in this section.
  • Does the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. The concern may have been caused by binding or incorrect pivot arm adjustment. REFER to Windshield Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
INSTALL a new windshield wiper motor. REFER to Windshield Wiper Motor in this section.
Maruti Gypsy wiper kit with motor
u need to order these items at any authorized maruti service centre.,as spares wont be availble in after market
2answers
The wipers will start, then stop like someone is holding them, then in a while they will try to move again, then stop off and on
when it happens you can use a hammer and tap the motor, if it starts the motor is worn and needs to be changed. also check the ground for the wiper motor. when it happens again connect a ground wire from the motor body to a good ground if it starts permanently connect the wire. these are the 2 most common problems that can occour.
2answers
How do do I Fix windsheld wippers.
Check the relays. The check for 12V at the wiper connector. Also check for a good ground between the wiper body and any metal surface. If they check out OK, but unit still wont run. Identify the 12V input to the motor. Connect it directly to the battery positive post. Unit runs problem is with the BCM. Unit does not run unit is bad or internal electronic controls is bad. Chrysler loves to run everything through the BCM (totally unnecessary) but it makes them a pile of money since many small things lights, etc run through the BCM and when they go bad the BCM needs replacing at $600 a crack! Nice scam huh?
2helpful
Rear wiper will not shut off
the motor in all wipers motors boxes.
has a switch inside, called the keep alive or auto cancel;.
its bad.
ive fixed many a switch inside, most shops throw the whole thing way.
for good reason, they dont want you back next week for same problem.
on old cars we try to fix things. direct.
to prove this. we use a voltmeter
at the 2 power pins, one goes to 0volts when you turn it off
the other stays hot. 12v. this is normal
if the motor fails to stop, the motor internal switch is bad.
the tests are here.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
under wipers chapter and wiring 8w-53-4
as you can see the rear motor has 3 wires.
pin 2 is ground
pin1 is keep alive pin, 12v.
pin 3 is demand, 12v wiper on, 0v wiper off.
if you cut the pin 3 wire, and the motor keeps going, the motor internal switch is bad.
if cutting pin 3 , kills the motor ,that means the hand switch is bad.
or shorted some way.
1helpful
2005 Jeep Grand Cherokee font wiper problems. wipers will not park all of the time. when you start Jeep or shut off vehicle, wipers will cycle once. switch is in the off position. dealer replaced wiper...
both blades fail to park.?
are the arms installed correctly?
so the wipers run , when you key on. ? is that it
tell me when exactly they move, and you didnt commend it.
here is how i do this, i log in to alldata.com
and see its a complex set of 5 parts, in the wiper schematic
2 relays (on/off and hi./low) and the wiper motor and the switch
and the controller.
so i take my handy voltmeter ($10 at walfart) and measure
pin 30 of the wiper relay on/off.
if it reads 12vdc (keyon, or off, with wipers off) this is a bad reading
if it reads 0v, , its good. easy huh
but what if the relay 30 pin read 12v
what would i do, id see if its being told to turn on.
id pull it out, is the wiper dead now. (yes, might be bad relay)
but id check the voltage across the 85/86 relay coil pins
12v is bad, the IPM is commanding wipers full time. (keyon)
0v is good, and relay is TOAST>
The IPM is the thing that holds the wiper switch.
it too can fail but i bet not.
1998 Avant Rear wiper problem Rear wiper has stopped working. Before it fully died it would try to move but only a fractionbefore stopping. I have removed the motor and directly powered the two outer...
How much current is the motor drawing? Most wiper motors draw between 8 and 10 Amps when they are working properly. If it is drawing considerably less, then the brushes are worn out. If it is drawing considerably more, the armature is shorting.
Testing the motor with it removed does not check to see if it can carry a load. The same tests should be done with the motor installed and carrying it's normal load (including friction resistance from the wiper blade). I have a feeling you will see a HUGE voltage drop between your 1st and 3rd pins if it is tested this way. If so, replace the motor.
Wipers don't work on intermittent. They run but stop in they middle of the windshield and don't go to the bottom like normal, Then they run again and stop some other spot. When put on continuous they...
The intermittent wiper speed is activated with grounds controlled by the multifunction switch inputs to the windshield wiper motor module. The windshield wiper motor module then activates the windshield wiper RUN/PARK relay coil and switches voltage through the windshield wiper high/low relay. The high/low relay remains deactivated supplying the voltage to the wiper motor low speed input and activates the windshield wiper motor. When the windshield wiper motor module receives the grounded input, the motor continues to operate until Hall effect senses magnet to turn off RUN/PARK sense the output to the windshield wiper RUN/PARK software, deactivating the relay and disconnecting voltage to the wiper motor. The windshield wipers remain parked until the windshield wiper motor module completes a time-out and then repeats the intermittent windshield wiper cycle.
  • The intermittent windshield wiper speed does not operate correctly
  • Multifunction switch.
  • Circuitry.
  • Windshield wiper motor.
  • Go To Pinpoint Test D .
Pinpoint Test D: The Intermittent Windshield Wiper Speed Does Not Operate Correctly
Normal Operation During normal operation, the windshield wiper motor receives voltage at all times through battery junction box (BJB) fuse 1 (30A), circuit 65 (DG). The windshield wiper motor also receives power with the ignition switch in RUN or ACC positions through central junction box (CJB) fuse 33 (15A), circuit 1002 (BK/PK). Ground is provided to the windshield wiper motor through circuit 676 (PK/OG) and circuit 57 (BK). The run/park and high/low relays are contained in the wiper motor electronics. Mode of operation is dependant on the signal(s) received from the multifunction switch.
    Possible Causes
  • Open in circuit 57 (BK), 56 (DB/OG), 61 (YE/RD) or 63 (RD)
PINPOINT TEST D: THE INTERMITTENT WINDSHIELD WIPER SPEED DOES NOT OPERATE CORRECTLY Test Step Result / Action to Take D1 CHECK THE MULTIFUNCTION SWITCH
  • Did the multifunction switch pass the component test?
Yes
GO to D2 .
No
INSTALL a new multifunction switch. REFER to Section 211-05 . TEST the system for normal operation. D2 CHECK CIRCUIT 57 (BK) FOR OPEN
  • Measure the resistance between multifunction switch C202b-6, circuit 57 (BK), harness side and ground.
Yes
GO to D3 .
No
REPAIR the circuit. TEST the system for normal operation. D3 CHECK CIRCUITS 56 (DB/OG), 61 (YE/RD) AND 63 (RD) FOR OPENS
  • Using the following table, measure the resistance between multifunction switch C202b harness side and windshield wiper motor C125 harness side:
    Multifunction Switch C202b Windshield Wiper Motor C125 Pin 2, circuit 56 (DB/OG) Pin 10, circuit 56 (DB/OG) Pin 4, circuit 61 (YE/RD) Pin 1, circuit 61 (YE/RD) Pin 1, circuit 63 (RD) Pin 9, circuit 63 (RD) Pin 3, circuit 58 (WH) Pin 11, circuit 58 (WH)
Yes
GO to D4 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. D4 CHECK FOR CORRECT WIPER MOTOR OPERATION
  • Check for:
    • corrosion.
    • pushed-out pins.
Yes
GO to D5 .
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation. D5 CHECK THE WINDSHIELD WIPER MOTOR
  • Did the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. Concern may have been caused by incorrect binding pivot arm adjustment. REFER to Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
2helpful
The wiper motor on my 1983 Ford Ranger still works but the wipers no longer move. I think there is a failure of the mechanical linkage. Where do I go to find repair parts?
why do you think the motor still works if the wipers don't move? Can you hear the motor run or can you see a little movement when you turn the switch on?
What happens when you activate the washers?
go to a salvage yard that allows you to remove the parts yourself. Then you can see how the motor and linkage assembly comes out.
don't have 1983 info, but here is 1994:
Section 01-16A: Wiper and Washer System, Ranger/Explorer 1994 Ranger and Explorer Vehicles Workshop Manual
DESCRIPTION AND OPERATION Windshield Wiper System, Ranger/Explorer The windshield wipers are actuated by a permanent magnet, rotary-type electric windshield wiper motor (17504) . The two windshield wiper pivot arms (17526) and windshield wiper blades (17528) are mounted on a pivot shaft, one at each side of the windshield. The windshield wiper mounting arm and pivot shaft (17566) are connected to the motor by windshield wiper adapter and connecting arm clip (17531) . Ranger and Explorer vehicles are equipped with an interval wiper and washer (IWW) system featuring a lever-type turn signal and windshield wiper switch (13K359) mounted on the steering column. The IWW windshield wiper governor (17C476) uses a relay contact to control current to the windshield wiper motor . The governor electronic circuitry controls the contact to supply current to windshield wiper motor . A rear wiper/washer system is available on Explorer vehicles. The rear window wiper system consists of a windshield wiper motor mounted inside the liftgate (40010) , an articulating windshield wiper pivot arm and windshield wiper blade , a windshield wiper/washer switch (17A553) and an inline circuit breaker. The front electric windshield washer system consists of a control switch, integral with the turn signal, a windshield washer reservoir (17618) and windshield wiper motor and the necessary windshield washer hoses (17A605) , windshield washer nozzle jet and brackets (17603) and attaching parts.
Pivot Shafts and Linkage Removal and Installation
NOTE: The left and right pivot and windshield wiper adapter and connecting arm clip assemblies are serviced separately.
  1. Perform Steps 1 through 9 of Windshield Wiper Motor Removal as described in this section.
  1. If servicing left windshield wiper adapter and connecting arm clip , remove left windshield wiper mounting arm and pivot shaft and windshield wiper blade assembly.
  1. Remove left windshield wiper adapter and connecting arm clip access cover.
  1. Remove left pivot nut, lower windshield wiper adapter and connecting arm clip and slide it out through left access opening. For installation, follow removal procedures in reverse order. Tighten nut to 10-13 Nm (7-10 ft-lb). Make sure the clip is fully seated in the windshield wiper adapter and connecting arm clip . Do not try to install clip with windshield wiper adapter and connecting arm clip on motor crank pin.
Windshield Wiper Motor Windshield wiper motor are not serviceable. If worn or damaged, the windshield wiper motor must be replaced as an assembly. Removal
  1. Cycle windshield wiper blades until in straight-up position and turn ignition switch OFF.
  1. Disconnect battery and wiper motor electrical connector.
  1. Remove the right windshield wiper mounting arm and pivot shaft and windshield wiper blade .
  1. Disconnect the battery ground cable (14301).
  1. Remove the right pivot nut and allow the windshield wiper adapter and connecting arm clip to drop into the cowl top outer panel .
  1. Remove the linkage access cover, located on the right side of the dash panel near the windshield wiper motor.
  1. Reach through the access cover opening and unsnap the wiper motor clip.
  1. Push the clip away from the windshield wiper adapter and connecting arm clip until it clears the nib on the crack pin. Then, push the clip off the windshield wiper adapter and connecting arm clip.
  1. Remove the windshield wiper adapter and connecting arm clip from windshield wiper motor crank pin.
  1. Remove nut and ground strap.
  1. Remove three attaching nuts from windshield wiper motor. Remove the windshield wiper motor .
Installation
  1. Position the windshield wiper motor and install the three attaching screws. Tighten to 13.6-19.0 Nm (10-14 ft-lb).
  1. Install nut and ground strap.
  1. Connect wiper motor electrical connector.
  1. Install clip completely onto right windshield wiper adapter and connecting arm clip. Make sure the clip is fully seated. Do not put the windshield wiper adapter and connecting arm clip on the motor crank pin and then try to install the clip.
  1. Install the left windshield wiper adapter and connecting arm clip onto the wiper motor crank pin.
  1. Install the right windshield wiper adapter and connecting arm clip onto the wiper motor crank pin. Pull the windshield wiper adapter and connecting arm clip onto the crank pin until it snaps into place. The clip is properly installed if the nib is protruding through the center of the clip.
  1. Install the right windshield wiper mounting arm and pivot shaft and nut. Tighten the nut to 9.5-12.5 Nm (84-110 in-lb). NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
  1. Connect the battery ground cable and turn the ignition switch on. Turn turn signal and windshield wiper switch off so windshield wiper motor will park, then turn ignition switch off. Replace right windshield wiper adapter and connecting arm clip access cover.
  1. Install the windshield wiper mounting arm and pivot shaft and windshield wiper blade assemblies on the pivot shafts to dimension X. Dimension X is the distance between the centerline of the blade saddle and the top edge of the cowl top outer panel grille. The value of Dimension X for each vehicle is given in the Dimension X chart in the Specifications portion of this section.
  1. Test the system.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
