You can purchase a Bauer MF-588 Air Cooler & Heater Watermat Motor from an authorized retailer. You can also find the manual for your motor online. You can search for the specific make and model of your motor to find the manual. Alternatively, you can contact the manufacturer of your motor to request a manual.
Yes, it is possible to reverse the rotation of the LR63420 Model D motor from CW (clockwise) to CCW (counterclockwise). Here's how to do it:
Turn off the power supply to the motor.
Remove the motor cover to access the motor terminals.
Identify the two wires connected to the start winding of the motor. These wires are usually marked with the letter "S".
Swap the positions of these two wires. For example, if wire A is connected to terminal 1 and wire B is connected to terminal 2, then disconnect wire A from terminal 1 and connect it to terminal 2. Then disconnect wire B from terminal 2 and connect it to terminal 1.
Reinstall the motor cover.
Turn on the power supply and test the motor to see if it is now spinning in the desired CCW direction. If not, repeat steps 3-5, making sure to swap the correct wires.
Note: Reversing the rotation of a motor may affect its performance and should only be attempted if you are experienced with electrical wiring and motor repair.
Your washer apparently did not complete diagnostics. The display indicates that it stopped at the segment of the test where it was attempting to fill by using the hot water solenoid. The diagnostic test segments check the following:
C:00 - Door Lock
C:01 - Flow Meter, Cold Water Solenoid
C:02 - Dispenser Motor, Dispenser Contacts
C:03 - Hot Water Inlet Valve
C:04 - Motor rotates CW at wash speed
C:05 - Heater & NTC (Heater Sensor)
C:06 - Drain Pump
C:07 - Motor rotates CCW at 35 to 90 rpm within 15 seconds
C:08 - Motor rotates CCW at max. speed.
If there is an error associated with any portion of the diagnostics, the washer will shut down, an audible alarm will be heard, and an error (F) code will be displayed. Sometimes the washer will experience momentray glitches during testing, however. I would recommend unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). The is the main "brain" of the washer. Upon reset, attempt diagnostics again and let me know the results. I hope this helps you.
