The rinse is supposed to start during the spin...it's what removes most of the soap from your clothing! The spin forces the water through the clothes, flushing all but a small amount of the detergent away. The rinse cycle itself is more to remove solid debris that may have become trapped in the folds of cloth. It does so by floating and agitating the clothes.
The quick wash cycle is only for things that aren't soiled much, that you need to be done fast. It's not for everyday washing, just for things that maybe need no more than a freshening up. It makes it faster by cutting corners.
Wow that's a strange one.
Are you pouring the soap into the tub onto the clothes or using a soap dispenser? If using a dispenser, it may be malfunctioning, try pouring soap directly into the tub under the waterfall while it is filling.
When the machine is agitating are the clothes on top being drawn under the water? Usually this occurs as a rolling motion from the edge of the tub towards the agitator. If the top layer of clothes have an air bubble trapped in them they may not be submerging into the water. Any soap on top may not be dissolved.
Finally, if you are pouring soap into the tub, make sure you are not spilling any onto the inside of the lid or in the softener dispenser. It could get trapped in the lip around the edge of the lid and be spilling onto the clothes when you open the lid at the end of the cycle.
Do you have the same problem if you use powder soap?
INSIDE THE AGITATOR IS A PLASTIC GEAR AND SOME DOG EARS WHICH GRAB THE AGITATOR,,,USUALLY ITS THAT,,CALL YOUR LOCAL APPLIANCE PARTS STORE,TELL THEM THE BRAND AND THEY WILL KNOW JUST WHAT YOUR TALKING ABOUT AND YOU NEED,,ITS A SIMPLE FIX,,NO NEED FOR TECHNICIAN,,
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS.
I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ...
OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ...
IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE.
GOOD LUCK AND STAY DRY !!!
