Uniden DECT 6.0 Cordless Phone ID Logo
A
Anonymous Posted on Apr 06, 2015
How to lessen number rings before going to voice message
Art Cacella
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 186 Answers
  • Posted on May 16, 2016
Art Cacella
Expert
Level 2:
Passionate:
Answers
186
Questions
Helped
55443
Points
242
To set the Answer Machine System's Number of Rings,
model D1680 or similar:
1. press [MENU]
2. scroll to "Ans. Setup" then press [select]
3. scroll to "Ans. Setup / Ring Time" then press [select]
4. scroll through the choices, at desired one press [select]
5. (chirp) press [END] to conclude & exit
How do I increase the number of rings before it goes to voice mail
What type of phone is this? Most home phones have a setting in them to adjust the number of rings. Retrieving voice mails requires the voice mail be set up first. To assist you further, please provide more details.
2answers
Voice Mail
go iin option under ringers cheak to see whats its on before voise mail picks up 1 3 6 10 ? isnt it in the optimns menu or if u have seprate unit for voise mail cheak setting on that beofre it grabbs the call does that help
Can't call from Voice
Ok, there is one thing you can try first:
1. Go to your Google Voice account at http://voice.google.com
2. Go to settings by clicking on the gear in the upper right corner
3. Select phones
4. Find your mobile phone number and see if the option "Activate Google voicemail on this phone" shows next to it.
Is this already activated?
6helpful
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
I DONT WANT TO HAVE YOUR PROMO CALLS OR MESSAGES IN MY NUMBER 9745006947
one way to solve this, find a phone number that is not working. on your phone you have several answer settings. ring and answer, ring and let it go to your voice mail, and the ignore button. that will send it straight to your voice mail, or any other number you set it to go to. their computer will pickup the tones of the out of service phone and drop you from their calling cue.
How to change number of rings
Not sure how to change the number of time it rings but to change your voice message call yourself, put in your pass when it tells you to then press 4. Now press 3. Now press 1. To have a standard greeting with your number press 1, to have one with your name press 2, and to make your own press 3. Hope this helped.
2answers
Voicemail
go to the voice mail options on your phone then press on something containing to voice mail number then put in 1 then area code and then the number if that don't work call voice mail and Lessen for voice mail options and do the same
13helpful
2answers
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
2answers
Message Greeting
The KX-T7456 is a proprietary system phone. You have a Panasonic phone system and a voice mail, both separate items with their own part number. Your phone can work on several different systems and use different voice mail so your first step is to determine the part numbers from the system and voice mail. Then you will need a "programming" manual or possibly "administrator's manual" NOT a "user guide" for at least your voice mail and maybe for the system as well.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
