Hello my zmodo dvr starts loading then shuts down then starts loading again
SOURCE: Have to slam the lid
The same thing happened here. It turned out to be the lid switch. It
can be accessed by taking off the back plate (behind the controls) by
unscrewing three screws and two screw bolts -simple.
I removed
the lid switch and tested it with an ohm meter - instructions are on
this site. You should have continuity across machine-motor, as well as
across machine -line. (These are labeled on the switch).
If you
don't have a meter and you still want to see if that's the problem,
after you have removed the lid switch, short the machine and line
connectors, (you'll see these labeled on the lid switch so you'll be
able to figure out which wires go with what) as well as shorting the
machine and motor connectors. Both of these need to be shorted. That
bypasses the switch and will activate the motor and controls.
That's
what I did to confirm that it was all a "lid switch " problem. I
ordered a lid switch from this site for $24.95 for the repair, and will
use the "shorting process" to do a couple of loads of wash as I wait
three days to get the switch. Good luck.
SOURCE: pc keeps loading and restarting again, it wont go past windows xp
well,eventually if it started several times the good configuration you will take is that also to restart again,it better to move on to safe mode in order to restore your windows normally that process will restore your some missing file to start up.after windows appear.
click start,click all program,click accessories, click system tools,click system restor until system restore appear just select any date that system restore will correspond to your request( I prepare past date)then follow the restore system what to do until it will restart again your PC Observed there will a long time to restart just let it be make the restor system is fixing your start procedure then finish it will now appear your refresh windows.if you shutoff and start again it will put back to normal operation.If the problem occured again some virus is inside your hardisk reformat your windows.
SOURCE: My VGN FS920 shuts down at the window loading screen
ok no need to get a bcakup disk or downlaod anything
if ur hard drive is original factory fitted
and
ur laptop came with pre loaded OS as XP
then do this without disk
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
pls let me know and rate me FIXYA for help
SOURCE: the loading 'logo' wont disappear. pls help.
Hold the power button down. Keep it down until the unit powers off. Then press power to start the machine up, and as soon as you hear the starting chime (boooong) press Command+Option+P+R and keep them held down until you hear the startup sound 3 times. Then you can let go and it should start normally.
SOURCE: Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
