You need to check on the connecting cables if damage replace,you can as well check my computer in system programms on monitor/visual display unit to see new device connected to system, after that restart your system.
you need to check on the connecting cables if damage replace,you can as well check my computer in system programms on monitor/visual display unit to see new device connected to system, after that restart your system.you need to check on the connecting cables if damage replace,you can as well check my computer in system programms on monitor/visual display unit to see new device connected to system, after that restart your system.
You can't post conmments that contain an email address.
This means you have problems with either your Toner Ctg, Developer Unit or worst Drum Cartridge I would start with Toner do you remember which toner ctg you installed or recently replaced ?
Hi ,
The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc" uploaded on site http://www.esnips.com/web/papputatiyasStuffIt will be helpfull for you.You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken. Happy debuggingMukesh
I have had the same problem. That error represent a document still in the scan path. You will probably find there is no paper in the scanner. I tried this and it works every time. On the top of the scanner there is an access door. You will find this just above the discharge rollers. Open that door and either blow air in the compartment or blow hard using your mouth to clear dust. Close the door. That should resolve the problem. It is my guess that dust collects on sensors and the scanner is tricked into thinking there is paper in the path.
