You need to talk to your carrier and get a new SIM card, it will not work w/o the appropriate card. I had the same issue when moving from a 1st gen to a 3Gs and ended up going to the store... )-; hope that helps.
Was it unlocked before, you need the original sim card the phone came with else it won't work
If your iphone was hacked and you did an official upgrade ? then it is not unlocked anymore
SOURCE: Iphone 1.0.2 unlocked does not recognize sim card
Im a wizz with the 1.0.2 Series, do you have msn messenger? I can send you all the files to fix it!
Shaun
SOURCE: does not recognize sim card
Take out the sim card clean it with a clean cloth and inserted it back, Still if it is not working Press the power button till you get the power to slide option and then try hope this will help you.
SOURCE: the iphone 3g will not recognize an incerted sim
If the sim card, is an at&t card then contact a at&t store close to you and have them check the card.
If the sim is not a at&t card, the phone has to be unlocked so it can use other carriers.
If this is the case ,post back and ask how to get your phone unlocked.
I can help you with this issue, but I need more information.
What SIM carrier are you using?
What firmware are you running?
What baseband do you have? (Go to Settings>General>About>Modem FW)
