Question about Apple iPhone Smartphone
How do i access or copy my sim contacts from the sim to the phone?
Posted by progressenka on
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
Actually, you can import contacts from SIM to iPhone with simple steps. Just follow below guide.
iPhone doesn't store contacts on the SIM card. If you want to transfer contacts between iPhones, you can use iCloud to backup or transfer content between devices. When it comes to import contacts from SIM card to iPhone, users will only need three simple steps.
  1. Remove the SIM card from the old phone, and install it on your iPhone.
  2. Your iPhone may need to reactivate. If so, connect to iTunes.
  3. Tap Settings > Mail, Contacts, Calendars > Import SIM Contacts.
  4. Wait for the import to complete.
  5. If you swapped SIM cards in step 1, remove the SIM card and replace it with your iPhone SIM card.
  6. Open Contacts and make sure that the contacts imported.
The contact information imported from a SIM card depends on how your previous phone stored information on the SIM card. For more help with importing contacts from a non-Apple phone, check the manufacturer's website, app store, or contact your carrier.After doing this, you will get the contacts in your iPhone. Transferring contacts from SIM card to iPhone is easy to be done when users have a suitable SIM card with iPhone. But if the SIM card cannot be recognized by iPhone, what should the users do to import contacts from SIM card to iPhone?
For more details, check: How to Transfer Contacts from SIM Card to iPhone
Posted on Jun 27, 2019
1 Related Answer
Anonymous
SOURCE: how to copy contacts from sim to phone
download simport from the IClarified section of the installer and you can import all your sim contacts to your iphone
Posted on Jun 30, 2008
How do I copy phone book entries to another handset?
1) Copy the contacts onto the SIM on the current handset, place that SIM into the destination phone and either access them from the SIM or copy them onto the new phone.
2) If no SIM then you may need to connect the phone to a PC and copy them using either a s/w program supplied with the phone or downloaded then connect your new phone and import them onto that device.
Sep 28, 2014 | Cell Phones
How do i copy contacts from my sony ericsson xperia x10 phone to my sim
Hi Barbara.
It's actually fairly simple to copy contacts on the x10.
Just access you phone dial pad via your menu
tap "Contacts" above the number pad
Press the bottom Left button (The real button at the bottom of the screen)
Should now pop a menu up with the option to copy contacts.
If not then tap the "More" option and it will be in there.
Now you have the option of copying them to the sim card or memory card.
Tap the relative option. :)
Feb 21, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Have a new Sony Ericson W995 and need to transfer contacts etc from Samsung U900. Instructions advise copying all contacts from sim to phone then put new sim in and copy from phone to sim. Have searched...
First delete all contact from your sim. Copy all contacts from your Phone book of samsung into card card. now your sim card have all contacts of your samsung phone contact list. Put sim into your new mobile Sony Ericson and copy all those contact from sim into phone contact list.you will be doing this by go to copy SIM contact into Phone Book option in your Sony Ericson.
This can also happens: When you put sim in ericson and switch on the cell it will ask you to copy contact from sim to phone memory.here you can press YES and all contacts get copied in phone
If you like solution, plz vote me
Sep 22, 2010 | Samsung U900 Soul Cellular Phone
How to copy the contacts in sim card to phone memory in Nokia E63?
how do i copy all my contacts from phone to sim card on my nokia E63
Sep 21, 2010 | Nokia E63 Cell Phone
When I want to go to my contacts that is on my sim card it gives me two prompts 1* Cant access contacts saved to service numbers 2* Cant access contacts saved to sim card How do I save my contacts on my...
To save contacts to phone. Do these;
1. Go to contacts> Scroll till you see Copy from SIM to Phone> It will then prompt you if you want to move all contacts to phone> Select 'Yes'.
Best regards
Aug 24, 2010 | Nokia 5800 XpressMusic Smartphone
I have saved all my contacts onto my sim from my old nokia ph. I am trying to access them now on my new nokia e65 but they are not there what do i do
HI
To copy contacts from a SIM card to device memory,
Go to contacts--------->select Options----> SIM contacts -------> SIM directory to open the SIM directory.
-------->Mark the contacts you want to copy, or select Mark all to copy all contacts.
Select Options --------> Copy to Contacts.
all the contacts wil be copied to you contact list.
Jul 15, 2010 | Nokia e65 Cellular Phone
Cannot access SIM contacts or SIM card
If you go into menu and press contacts, options, select sim contents, sim directory and the go back to options and mark/Unmark, then select mark all. Your phone will automatically tick all the numbers on your sim. The last thing is to press options again and copy to contacts.
Let me know how you get on with this but l guess this should fix your problem.
May 06, 2009 | Nokia e65 Cellular Phone
Contacts
Your SIM Card is like a floppy disk, so if you want to permanently add those people from your sim card to your Blackberry - you need to copy from the SIM into the BB Address Book. Otherwise they will be on the SIM Address Book, and you can always go look them up - but they are not saved on the BB itself.
BB: To access your cell phone address book:
  1. Scroll to select the ADDRESS BOOK icon and press [Trackwheel] to select.
  2. Press [Trackwheel] again to access the Menu screen for the address book.
  3. Scroll to select the SIM PHONE BOOK and press [Trackwheel] to select.
  4. system should say LOADING SIM PHONE BOOK.
  5. Then if you select the menu - you should have an option to COPY ALL TO ADDRESS BOOK, select YES so it will copy whats on the SIM to the BB Memory..
This will start the download process to read the contacts stored on your SIM card which were copied from your cell phone.
Mar 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
Arrows don't work...can't save contacts to SIM
hi,
  your arrow keys have problem, so take it to the service center for repair..now i ll tell you how to access ur phone without arrow keys.. imagine ur menu is like wat i shown below..
       cal log      phonebook      applications
       browser    messages       files
       calendar   camera           settings
now if u want to access "cal log" press 1 ; "phonebook" press 2; " applns" press 3 ; "messages" press 5.....like this as in your keypad...
now select contacts by pressing any suitable number...select options...assume if your options are placed like this
view
create contact
send via
delete
copy to sim
then u can access view by pressing 1, create contact by pressing 2...and copy to sim by pressing 5....do it as it is in ur mobile...
good luck
Jul 03, 2008 | Motorola Mobility RAZR V3
Apple iPhone Smartphone Logo
66 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
