SOURCE: PANASONIC KXTG5432M PHONE
No, you cannot add a set to this phone. But if you are going to up grade then buy one that says expandable. KXTG5433M has only 3. Some Expandaables can have up to 10 or 12.
SOURCE: Why did my Panasonic phone quit charging in base unit?
Check the condition of the charge contact tips in the phone cradle, there are uaually two or three spring loaded pins that contact the phone charge contacts. Make sure these are clean and the springs still work. If these are good, you can check the output of the charger with a volt meter at the spring loaded pins, you can get the correct voltage off of one of the satellite units and compare it to the base. If the base is not putting out the same voltage the charger has likely failed.
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
