20 Most Recent
Panasonic SA-HE7 Receiver Questions & Answers
Intermittent F70 Error
F70 interrmintent problem caused by (Ic-current) interupted, supply for cpu, Q1702 (emitter point) high resistant to IC1701, suggestion- connect a wire between these component due to pcb track poor contact.
I have panasonic sa he7. My problem is error f70 overload.There was a electrical failure in my speaker. After that reciever showed f70 overload error. Fuse is not the original one. After that every ti
You may have a speaker connected that the amplifier cannot drive. Your receiver is compatible with speakers with 6-8ohm rating, however, even though your speakers may be operating within that range they may also have low sensitivity.
With the receiver turned off, disconnect the power cord for a few minutes, reconnect and then power it back on. And while you're behind the unit, that would be the convenient moment to inspect your speaker terminals...check for cracks, evidence of arcing and any stray pieces of strand wire that can touch the chassis or other terminals. If any of those conditions exist then that can a root cause of the problem and will have to be repaired.
You must also ensure that all of the chassis vents are not blocked and the unit does not have another device on top of it that also generates heat as well. In any event, keep it cool.
After that, enter into your speaker setup menu and adjust your crossover to a higher point for whichever speaker you had the failure. This will help control the overload condition, if in fact, it is being caused by your amplifier ability to drive your current speakers.
If after all of the above is performed and the condition still exists, try speakers with compatible ohm rating but higher sensitivity.
Channels
Check your cables and then move the channel selector through all settings a couple of times. This will give some indication of the real problem. If the channel comes back after exercising the channel selector, then you have a "Furred up" selector. If the channel doesn't come back then you may have a failed amplifier in the amp.
My panasonic amplifier when i
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers
Can I adjust the level of each channel from the
Depends on the reciever, some due and don't, my advice is to get a universal remote that will work with your reciever and then you can adjust your settings no problem. I own a Yamaha RX-V3800n and you can hardly do anything without the remote.
Hope this helps
Overloading
hi mate, ive had the same problem before with this amp. i bought it new aout 6 years ago and bought another new one about 1 year ago, new, for £70!
on the first amp there was a problem with the surround sound aspect, it kept overloading when turned up even a fraction, it would tick 4 times and power off. Eventually the surround sound stopped working all together and whenever selected made a VERY VERY loud hissing/crashing noise through all my speakers, blowing one of them, SO BE VERY CAREFULL.
when that happened i assumed was broken so bought another one, and had same overload trouble when i got a new speaker package.
Im pretty dam sure it was the ohmage ratings being different on 2 of the surround sound speakers that srewed the 1st one, so id suggest you check theyre all ok, as well as the speaker watt-age.
what are the specs on all your speakers (ohms and watts RMS)??
do you listen to LOUD music through the 5.1 option??
hope this helps, if all else fails buy a new one mate, theyre so cheap. go into panasonic shops and see if they have any left.
Panasonic Receiver Model No; SA-HE7
Perhaps what might help is to get hold of a Service Manual to be specific on the Part Number or Board Number.
An alternative is to go down component level and replace defective discreet components.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
