I guess your either using the scart socket or the HDMI socket. You have gone into the menu and changed your input source to either HDMI or Scart havent you? Does your TV aerial input work when switched to Antenna on the input source menu. If these dont happen then you have a faulty main pcb.
I don't know how you connect the unit to the tv. Let's just start on basic: composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV. If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable! Good luck!
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
I received an e-mail from Samsung which reads
"What you have described in your e-mail was an issue that was logged and has been investigated we have released a firmware update to resolve the issue"
also
"In order for the firmware to be updated on the unit please call our product support team on 0870 726 7864 for assistance"
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
