If you are talking about a desktop / tower, you have a lead that goes from your wall socket outlet to the rear of the computer the end will be shaped like a kettle lead, in the trade we call them "kettle leads" Google image search and you will find it.
Now if you are talking about a laptop.
You have a lead that goes from your wall socket outlet to a mains charger and that's where the mains lead stops DO NOT try and plug that directly into the laptop.
Now with laptop mains leads you have three different types;
1) IEE
2) Cloverleaf ?? think of leaf with three petals
3) Figure of eight ??
If you Google image "computer mains leads"you will see the three different types including the IEE
To energise your laptop with or without a battery and after your mains lead you will need a "computer charger" or a "laptop charger"
On the underside of the laptop there will be a "rating label" telling you of the various voltages.
Or an easier way is to Google your laptop make & model
To get onto the internet you need either a Wi-Fi connection or a wired connection which is an RJ 45 plug Google the image RJ 45 and you will have your answer.
Good luck
From looking online this message indicates the following: "A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or homegrown applications."
The advice for resolving this issue is as follows: 1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off and then back on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance. 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter and calibrate the printer. See Calibrate now.
Error 49 is usually a critical firmware error which cause the processor on the formatter to abort operation.This type of error can be because of
invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during
cables or poor connections, To solve this try this solution step by step:
the
each
device.
If the error persists, final option is replace the firmware or best & final option is to just contact to any HP service provider
I hope this solution will be helpful for you. Anymore help, I am here to help THANKS and keep Visiting FixYa
Fault(error) 49 is a critical firmware error which cause the processor on the formatter to abort operation.This type of error can be because of
the
each
device.
I hope this solution will be helpful for you. If it is HELPFUL, Your Rating as FOUR THUMBS will be esteemed. THANKS and keep Visiting FixYa
Hi , One side of the lead is designed to fit on the computer , the other one on your HP unit . If nothing fits on any side , you need to go back to your retailer where a correct cable will be given to you , in exchange for the previous one . Best regards .
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or homegrown applications. On rare occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
Solution 1 :
Go to START MENU Choose RUN Type the letter "cmd" Type the word "net stop spooler" Exit Go to C drive Choose to Windows Folder Click show content Choose system32 folder Choose spool folder Choose printer And delete all printing jobs pending Again go back to CMD window and type the word "net start spooler" Restart your computer also turn off your printer and switch it on. It will work fine right now I hope it helps you
Solution 2.
Check the printer driver using device manage and maybe it is corrupted. Try test page if necessary.
Solution 3.
Reinstall the printer software
Solution 4.
Check the network switch hub and maybe some loose connection.
Solution 5.
Solution 6.
Check the configuration of the printer is somethings not correct.
This is a firmware error and this error is usually caused by a bad formatter board.To troubleshoot this issue here are some steps that you can try .
2. Turn the printer off, and then turn the printer on.
3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.)
12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor-quality parallel cables, poor-connections, or home-grown programs. On rare occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
1. Turn the printer off then on.
2. Press Stop to clear the print job from the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message displays only with a certain software program or print job, contact the software vendor for assistance.
5. If the message persists with different software programs and print jobs, disconnect all of the cables to the printer that connect it to the network or computer.
6. Turn the printer off.
7. Remove all memory DIMMs or third party DIMMs from the printer. (Do not remove the firmware DIMM.)
8. Remove all EIO (JetDirect Cards) devices from the printer.
*Remember to protect from ESD
9. Turn the printer on.
10. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and on again as you install each device.
