SOURCE: Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
SOURCE: Ice maker
I would replace the water filter on the back of the refrigerator.they eventually become clogged and prevent the normal water flow to the ice maker.
SOURCE: The ice maker makes a burping noise when the ice bin is full
This is normal. Do no let it bother you. As long as there is ice production there is not a problem.
SOURCE: frigidaire glrs267dzw2 side-by-side mfg 11/2004 -
Looks to me your model had the older style ice maker that uses micro-switches to tell what is next in the six parts of one complete cycle. Some times those switch's stick on or off and tend to break. Here is a link to an exploded view=> 5303918344 Ice Maker Exploded View
Let me know if you have any questions so I may help you better, Thanks, Sea Breeze
You can try to disassemble and repair, just be aware that the lever spring will be the hardest part to understand putting back in if you by chance pull the facing off it can jump out of its location giving you hours of fun trying to return to its proper place. The ice maker replacement part is=> Click on photo or 5303918344
SOURCE: Our ice maker keeps making
I cant id the model #. Does the I/M have a bail arm or is it optical. If it has an arm lift it to the upmost position. It should stay there and keep the ice from harvesting. If it does not you Might need a new I/M.
