SOURCE: having problem installing office 2007 on Microsoft office Vista
Hi Noglao, I have experienced similar problem with my Office 2007 installation, I believe its a problem with the CD itself, there might be a scratch or something that is blocking this file from being read. Maybe even a manufacture error since I had the exact same problem with the same file. In the end I had to copy the disk to my hard drive and I moved it to a share folder on my file server. I mapped this share folder to a root(z:) on my workstation. I ran it from there and it worked just fine. If you don't have a server or can't map a folder for some reason I suggest trying another installation CD, or copy the files to your computer, burn a new CD and try it again with that CD. Good luck Daniel
SOURCE: Cannot download ms office home
Hi, under control pael open ad and remove programs, uninstall this application if there and reboot and install again Or try going to your C drive in windows explorer and open the programs folder and check to see if this program is there, if so you can delete directly from there; be carefull you only delete what you need to. Good luck
you could go to major geeks to download open office which uses similar applications to Microsoft office 2007 and has many of the options of office 2007 bonus its FREE
http://www.majorgeeks.com/OpenOffice.org_For_Windows_d3461.html
http://office.microsoft.com/en-us/try free trial version word
hope this helps
don
