It sounds like the recorder will only record the dvd+ format, which does NOT need finalizing to play in other machines. ( you can record a dvd- , play it back on the machine you recorded it on, but need to finalize it to play on other machines) The other units may only accept dvd-.(dvd- being the same format as you would buy or rent a film on) One option, record the dvd on a dvd+rw (if possible) then copy to a dvd-r using your computer. The average use of a dvd+ is 1000 recordings. There are many free disc burning suites available to download. Just google "free disc burning software" and take your pick. I use 1 called "magix goya base" for copying disc to disc and "NTI" for burning to HDD and then to disc, if you only have use of 1 drive.
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
The first step to connecting a DVD Recorder to your TV is to
determine what type of connection you want to make between the TV
source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This
is usually determined by the outputs and inputs available on the DVD
If you have an older TV that only accepts
RF (Coaxial) input, then you would connect the RF output (a coaxial
cable) from your TV source (in my case a Cable Box) to the RF input on
the DVD Recorder. Then connect the RF output from the DVD Recorder to
the RF input on the TV. This is the most basic (and lowest quality)
option for connecting a DVD Recorder to any TV.
If you want to
use higher quality cables, then you may want to connect the TV Source
(Cable and Satellite only, not Antenna) to the DVD Recorder using
Composite, S-Video or Component video and audio cables.
To use
composite cables (also known as RCA, the yellow plug is video, the red
and white plugs, audio): Plug in the composite cables to the RCA
outputs on the back of your TV source and then plug in the composite
cables to the RCA inputs of the DVD Recorder. Then connect the RCA
outputs from the DVD Recorder to RCA inputs on the TV.
To use
S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video
output of the TV source. Plug in the S-Video cable to the S-Video input
on the DVD Recorder. Next, connect the RCA audio cable to the output on
the TV source and the input on the DVD Recorder. Finally, connect the
S-Video cable and the RCA audio cable to the output on the DVD Recorder
and the input on the TV.
To use Component Video cables and RCA
audio cables: Connect the Component Video cable and the red and white
RCA audio cables to the outputs on the TV source and the inputs on the
DVD Recorder. Next, connect the Component Video cable and RCA audio
cable to the outputs on the DVD Recorder and the inputs on the TV.
Now
that the TV source (either Cable, Satellite or Antenna), the DVD
Recorder and the TV are all connected, you need to configure everything
to make sure that TV is coming through the DVD Recorder, for recording
and viewing.
Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
If
you connected everything using the RF connections then the TV should be
passing through the DVD Recorder and displaying Television on the TV
screen. To record in this mode, you would need to tune to either
channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to
change channels and record.
If you made connections using
either Composite, S-Video or Component cables, then to view or record
TV, two adjustments need to be made. First, the DVD Recorder needs to
be tuned to the appropriate input, typically L1 or L3 for rear inputs
and L2 for front inputs. Second, the TV also must be tuned to the
proper input, on a TV usually Video 1 or Video 2.
If you have a
Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a
Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD
Recorder to the receiver to listen to audio through the receiver.
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
