Vacuums Logo
J
Jeffrey young Posted on Nov 30, 2014
How to replace foot lever on an Miele S7120 Vacuum cleaner
Removed footplate .
5 Related Answers
Anonymous
  • 112 Answers
  • Posted on Jan 15, 2008
SOURCE: gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Anonymous
  • 1673 Answers
  • Posted on Mar 22, 2008
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Anonymous
  • 80 Answers
  • Posted on Oct 07, 2009
SOURCE: Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Anonymous
  • Posted on Feb 08, 2010
SOURCE: Miele s571 vacuum cleaner power surges up and down
I just repaired the same problem. It is not the motor. There is a defective capacitor in the regulator. Large grey capacitor should have a value of 0.22uF/275V. It was in my case just 85uF. Changed capaitor and it was OK.
Anonymous
  • 2777 Answers
  • Posted on Oct 15, 2010
SOURCE: Instruction required for the removal of a full
Sure thing, the best thing to do is to have a look at the manual I have found here for you. The part you are looking for is on page 25 of the manual, complete with pictures and everything.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Here is the manual:
http://www.miele.co.uk/Resources/OperatingInstructions/S%205211_5781.pdf
Testimonial: "Thank you very much,we have missplaced our operating manual so this is just what we require,again our thanks"
How do I replace the upright locking foot pedal on my Bissell 3760-4
Replacing the upright locking foot pedal on a Bissell 3760-4 is a fairly straightforward process. Here are the steps you can follow:
  1. Turn off and unplug the vacuum cleaner.
  2. Lay the vacuum cleaner on its side so that you can access the bottom of the machine.
  3. Locate the locking foot pedal and use a screwdriver to remove the screws that hold it in place.
  4. Once the screws are removed, gently pull the old locking foot pedal away from the vacuum cleaner.
  5. Take the replacement locking foot pedal and position it in the same spot where the old one was removed.
  6. Use the screwdriver to attach the replacement locking foot pedal with the screws you removed earlier.
  7. Test the new locking foot pedal to make sure it works properly and holds the vacuum cleaner in the upright position.
  8. Once you are satisfied with the new locking foot pedal, flip the vacuum cleaner back over to its normal upright position.
  9. Plug in the vacuum cleaner and turn it on to make sure everything is functioning properly.
With these steps, you should be able to successfully replace the upright locking foot pedal on your Bissell 3760-4.
tip
How to Replace The Cord Reel in a Miele Canister Vacuum Cleaner
Ok, so you need to replace the cord reel on a Miele Canister Vacuum, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy a new Miele series cord reel for your particular model.
Here are links to all of the Miele cord reels if you haven't already purchased one.
Miele Cord Reels & Rewinds for All Brands
So once you have the cord reel, you'll need either a Phillips head screw driver for the older Miele models, or a T20 Torx Screwdriver for the newer models. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure is identical to most Miele canisters . You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter cartridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher position, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and components that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you,
Chris J.
GoVacuum
on Apr 07, 2010 • Vacuums
tip
How To Maintain a Miele Canister Vacuum
Here's a short Video Presentation that we've put together showing how to replace the vacuum bag, motor filter, and HEPA filter on the Miele Series canister vacuum, as well as how to perform basic maintenance.
How To Maintain a Miele Canister Vacuum Cleaner
Miele SKCR3 how to open vacuum cleaner
Slide the lever on top of the dirt to the side, lift the cup up slightly, and pull it straight out of the vacuum. On most models, the lever will slide to the left. Disassemble the dirt cup by popping the plastic top off the cup.
How can i get my upright kenmore vacuum cleaner to move to the vacuum position?
Don't know your brand vacuum but if I understand you correctly the solution should be pretty straight forward unless the lowering lever is broken somehow. Usually there is a foot lever on the left, or sometimes the right, toward the rear part of the base to push with your foot. Step on it while at the same time push it slightly forward first - just a quick 1" forward motion, then pull it toward you. That SHOULD disengage the handle to be able to vacuum freely.
2answers
My Miele Twist vacuum will not lock into the upright position. Also I sucked up a tassel from a throw pillow and have a clog. I took off the little clean out plate on back...it isn't in that par
to find that repair manual that you've requested and fix your vacuum so it can move into upright position, you can ask Miele to email you the manual by calling them at 888-996-4353
Thank you.
2answers
My parents have a miele vacuum cleaner model s538. Do you know where I can obtain a repair manual for this vacuum cleaner. It is always on the "fritz". The vacuum has been taken for several...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
http://m.miele.ca/OperatingInstructions/en-CA/Vacuums/Previous%20models/Miele%20Vacuum%20Cleaner%20Manual%20S500-548_S600-648.pdf
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Replacement Motor for a Miele S143 Vacuum Cleaner
Your vacuum should still be under warranty. If they dealer does not fix it for free call Miele directly.
Opening Miele S28i Vacuum cleaner
If it is similiar to the white star you may find the instructions here useful: http://www.sannerud.com/house/miele.html
hope so
Top Miele Vacuums Experts
john h
Ngoro
jws1013
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
