Everything fine in the process, but at the end the coffee is not good = "juice of black sock", very diluted.
I precise that i used special coffee for expresso machine. It's not a question of the quality of the coffee.
And when I prewarm the machine, the water is clear and hot.
So my deduction is going to a issue with the pressure itself? it is to low, not really 15bars? let me know what you think about that.
Thanks in advance
Raphael
[email protected]
white vinegar is a natural de-scaler (and cheaper than those specialist chemical cleaners) Lemon juice is a natural de-greaser, try a diluted solution then rinse it through with water. ;-)
Modern trainers and many types of shoe or boots may smell awful. Get some anti-fungal shampoo, make a dilute solution (not too dilute) and pour some into the boots or put the trainers into bowl of the solution and allow it to soak in and then dry out. The fungi and bacteria will be killed and this should last a few months. A second treatment may be necessary. The shampoo must contain one of the new (--onazoles) such as ketoconazole. You are looking for the ingredient name to end in onazole or very similar. Old antifungals are useless. transformed my work boots and stopped my socks from smelling for a few days when previously they would smell and need changing every day. Did wonder about soaking the work socks as well.
If your bpm goes down from 84 to 54 in just less than one month, you might suffer from low blood pressure. In this case, some food supplements can help you deal with this problem. However, before applying any of these treatments, you should consult to your doctors to ask for proper dosages.
1, Coffee
If you are a coffee fan then it can help with low blood pressure. You can consume a cup of coffee after waking up in the morning. Caffeine - rich foods can push up the blood pressure.
2. Beetroot Juice
In fact, this juice can help both high blood pressure and low blood pressure. To push up your bpm, you can take this juice twice per day until the condition is getting better.
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION. IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON. IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Most likely you burned the rubber gasket. UNPLUG your coffemaker!!! If you remove the gasket and the little metal filter attached by a screw and clean it off well and put a new gasket in it should solve your problem.
Clean it out with 1/3 caraffe worht of vinegar and 2/3 caraffe full of water - just brew the solution as if it were regular coffee - you may have to repeat this process up to 3 times.
If you use white vinager like most will recommend, then just pour diluted vinager. Put no more than one to one ratio into the machine like you would water for coffee and let it process just like when you make coffee.
