20 Most Recent Krups Bravo Plus 872 Espresso Machine Questions & Answers
You didn't say what model is your expresso machine.
You can find parts here:
http://www.krupsonlinestore.com/category.asp?MENU=parts
Krups Bravo Plus... | Answered on Mar 18, 2019
Sounds like a good cleaning or proper usage may be in order. Consult the manual for both.
Download Krups 872 Manual
Krups Bravo Plus... | Answered on Aug 28, 2014
Probably needs a good cleaning. Be thorough!
I can email you the manual in a .pdf file.
Already answered now.
Krups Bravo Plus... | Answered on Mar 03, 2014
Most likely you burned the rubber gasket.
UNPLUG your coffemaker!!!
If you remove the gasket and the little metal filter attached by a screw and clean it off well and put a new gasket in it should solve your problem.
Krups Bravo Plus... | Answered on Dec 08, 2012
Don't know if your still looking, but if you go in the customer service section of the Krups website (krups.com) and ask them for the manual they will email it to you. Or, email me and I can send it to you!
Krups Bravo Plus... | Answered on Dec 12, 2011
Hi if you "google" krups spare parts or krups espresso jugs you will get a few companies who sell spares. Also if you go to krups.com they will list their dealers for spares and accessories.
Krups Bravo Plus... | Answered on Oct 21, 2011
Krups manuals can be found online. Visit this site for the Krups 872.
http://lib.store.yahoo.net/lib/krupsonline/872.pdf
Krups Bravo Plus... | Answered on Oct 15, 2010
If you need the control module you will have to go to Krups. If you just need a relay I recommend Norvac. You can bring most any electrical component in and they can match it. I just found out they are only in my area. You can also check Radar Electronics and you could get lucky at Radio Shak. I hope that helps a little. you could also send me a picture of the relay and any numbers that are written on it.
Thanks, Mike [email protected]
I have a #872 model. It is very similar to the #871.
Where the gasket is there is a small metal filter too, attached by a screw.
If you unscrew the filter and remove it with the gasket most likely you are going to find the other side of it clogged by coffee. Wash it off and wash the gasket well too with dishwashing soap. Rinse them off well.
You should try to clean off the coffemaker part to where the gasket lays. Usually it is full of burnt of coffee.
If there is no other problem with your coffemaker this should solve your problem.
Krups Bravo Plus... | Answered on Sep 26, 2009
Hi Gilbert,
Krups still sell some parts for this model.
If you still looking for the boiler cap I think you can find it here:
http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+MS-0907815&MENU=parts&SELECT=espressomachines&SKW=PARTF872
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Krups Bravo Plus... | Answered on Apr 02, 2009
Krups Bravo Plus 872 Espresso Machine Logo
34 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
relay or
  • Coffee Makers & Espresso Machines
