Has a 6in dig. display on the left and the keys to the right of them. looks like a you could slide a credit card under the panel but the card slot is solid, no way to slide a card through it
SOURCE: sony ericsson w910i keys
mine has done that with the ok, L-select, R-select, end call, start call, deleate, and numbers 1, 4, 7
SOURCE: My key pad is lock and I forgot the pass code how
Normally, I would expect the default value to be the last 4 digits of your telephone number. If you changed it, you might be out of luck and require the intervention of your service provider or the manufacturer, http://www.samsung.com/us/consumer/mobile/mobile-phones/index.idx?pagetype=type
This is not the code that would allow you to take (for example) a Verison built phone to the AT&T system)
I hope this solves your trouble.
Free advice ... unless there are compellling reasons to invoke the lock, don't use it ... and make it the default value.
Thanks for your interest in FixYa.com
Please vote
thanks
a
SOURCE: my nokia 3600 slide power
you can calculate the master code of you phone for free at
http://www.nokialockcode.com
You have to write Just IMEI of your phone then you'll get the
master code of your phone.
