Sony Ericsson W910i Cellular Phone Logo
Posted on Mar 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dispaly Display goes blank when i slide up my w910i. Also sometimes the screen distorts, but when i slide down and slide up after key lock when the backlight goes of, screen is back to normal. Sometimes after sliding keys do not work. Changed the front panel recently.
iphone service
Level 2:
Guru:
  • Expert 228 Answers
  • Posted on Mar 06, 2010
iphone service
Expert
Level 2:
Guru:
Answers
228
Questions
0
Helped
46560
Points
696
Change the strip of display
Hie i have SGh e-250i when i open my slide then screen just turns in to white...i cant see who is calling or giving a message...when i turn it down then sometimes it shows a display and some times it...
Thats the problem of display chip. Only solution for it is to visit samsung service centre and replace the display chip. Most slider phone face this problem. I recommend to go to samsung service centre dont go any cellular repaiing as they will not give warrant for new dispaly chip and as per my experience samsung gives 1 month warranty...
Mar 12, 2011 • Cell Phones
3helpful
2answers
How to unlock?
To Unlock the Sony Ericsson W910I Model mobile from the Network lock You can use the Unlock Code You can get the Unlock Code at
http://www.wickedunlock.com/sony-ericsson-w910i/rs11wp9/ and Unlock the mobile following the Free Unlocking Instructions Below............
Sony Ericsson W910i Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson W910i mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson W910i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson W910i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson W910i does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2
6helpful
Sony ericsson w910i blank screen
this because of the strip inside the mobile...i think that got damaged in u r mobile...so u just give u r mobile to u r sony service sation and they will take care of u r mobile....and then u r mobile will be proper...be cool!!!!
Compaq screen goes blank after power up?
When yo upower up press F! or F2 or "del" key to enter in bios then check your harddisk is detected? if your harddisk is sata then enable sata option in bios then save settings.
If every thing is fine then it should be dispaly resolution issue.
When yo upower up vthe computer press F8 key then enter in enable vga mode then go to control panel then dispaly proeprty-> settings ->change screen resolution to 1024*768 then restart .
Thanks for using fixya.
Please rate this solution if it helps you.
2helpful
Screen
loose connection of the screen ribbon.
1helpful
Samsung E900
the flexcable needs to be replaced , take the phone to a mobile service center to have that done.
3answers
Freezing then blank screen
Have you tried pressing F8 on boot-up and log into safe mode under administrator, no password, and right click on any empty space on the desktop, left click on properties, left click on settings, select a lower resolution,( e.g. 1024X768 ) select apply, select ok, reboot, log in as normal
2answers
you have a loose connection, good luck....
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
