on PX650-PX659 error code 0x43
0x43
SCANNER
B Scanner/ADF FB PID lock error. Encoder failure. Tooth skip or improper tension of the timing belt. Gear crack. Cable or FFC disconnection. Motor driver failure. Main board failure.
This is the sensor problem. Check the following parts. PE Sensor, PW Sensor, CD-Tray Sensor. Also check the paper pickup roller is rotating or you hear the actuator sound before this error comes.
Error code 0xFB on an Epson PX660 printer indicates a communication error between the printer and the computer. Here are a few steps you can try to resolve the issue:
Turn off the printer and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again.
Check that the USB cable connecting the printer to the computer is securely plugged in on both ends. You can try unplugging and plugging it back in.
If the printer is connected to the computer wirelessly, make sure it is connected to the correct network and the signal strength is strong enough.
Try restarting your computer to see if that resolves the communication issue.
If the above steps don't work, try uninstalling and reinstalling the printer driver on your computer.
If none of these steps resolve the issue, you may need to contact Epson customer support for further assistance.
Hi I have a similar problem with Epson px660, it does not complete the self test after powering on then it flashes all lights with a printer error of fatal code 0x71, can you assist me kindly. Best regards
