Question about Epson STYLUS PHOTO T60 INKJET PRINTER
How I solve the Communication Error 21000068
Power light and Ink light is still on
Posted by Rashid Iqbal on
Tiffany Thor
HELLO Guys, just select the particular usb port and all is well..
Posted on Apr 25, 2019
Printer Help & Support
  • Epson Master
  • 783 Answers
Hi Rashid,
Step 1
Uninstall the driver that you have installed recently.
Open Devices and Printers by clicking theStartbuttonHow I solve the Communication Error 21000068 - clip_image001.jpg, and then, on the Start menu, clickingDevices and Printers.
Right click the printer-> Click on Properties-> click theDrivertab, and then clickUninstall. Follow the instructions.
Now download the drivers from the following link and install it and check if it helps.
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX425W/Drivers-Support
Install the driver and check if it helps.
Step 2
Try the Printer troubleshooter, which will attempt to automatically diagnose and fix your problem.
Open the Printer troubleshooter by clicking the Start button, and then clicking Control Panel.
In the search box, type troubleshooter, and then click Troubleshooting. Under Hardware and Sound, clickUse a printer.
Next, try updating the printer driver on your computer. Printer problems sometimes stem from out-of-date driver software, and can be solved by installing-or reinstalling-the latest driver.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Posted on May 30, 2014
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Communication error 20000068
This error usually means the AdjProg utility you're trying to use is not compatible with your printer model.
There's some more information on the issue here:
http://support.printerpotty.com/2013/error-21000068
May 01, 2013 | Epson TM-T60 Printer
Error 21000068
http://www.google.com.ua/search?q=error+21000068&oq=error+21000068&sugexp=chrome,mod=8&sourceid=chrome&ie=UTF-8
Nov 14, 2012 | Computers & Internet
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Communications error ! error code : 21000068
why is my comp displying "communication error code 21000068" when trying to reset epson tx650
Jan 15, 2011 | Epson TM-T60 Printer
Canon i9950: Full waste ink absorber
Dhedik maybe this action can solved your problem Reset Waste Ink Counter printer Canon i9950 :  1. power off  Printer
2. Push and hold resume  button and push power button
3. Hold  Power button and release Resume  button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and  stop.
6. When green light on, push resume button 4 x
7. Push  Power button and printer will off, if that isn't off, push power butto again until print off position.
ok good try, don't forger to vote me, Fixya
Apr 02, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Epson STYLUS PHOTO T60 INKJET PRINTER Logo
11,130 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
