J'ignore quelle est la marque de la tablette de votre enfant mais il se pourrait que ce soit un souci caus? par un d?faut de fabrication . Vous pouvez toujours remplacer certaines pi?ces,alors je vous recommande de cliquer sur ce lien https://www.distriphone.com/en/53-iPad-Parts
Restart it. Do not turn it off and then on but Restart it or reboot it. If the alarm still on try to find if it is wet somewhere. If it doesn't seem to be wet do it lightly with the hairdryer in a low setting. If it still has the alarm, it is wet somewhere that does not dry easily. Leave it for a few days and check it out again. If the alarm is still on, time to take it for service/repairs
It sounds to me like the internal memory petition has gone bad. When this happens it will retain no changes and boots up like it was when new every time it's turned off. Any changes are only retained if you put it to sleep and keep it charged. If the memory partition for apps has gone bad it will no longer be able to download or update apps from the Store and you will be stuck with the original apps and that is all unless you can managed to download some apps to an external SD card in the slot (if it has one).
You can tell if your memory partition has gone bad by using
Settings > Storage and observe the top bar graph. if it's green all the way across and shows 0.00 bytes of storage then the internal SD card memory partition is gone or the memory is defective.
Even so, you should still be able to synch using Google to do so. But, never turn it off again or you will be back to square one again and will have to do everything over and over and over.
I have a Nobis NBO9 that has this same problem. They fixed it once but it went bad again two weeks later. And, they balked at fixing it a second time so I got ripped off. I suspect there is a lot of defective internal SD memory cards in circulation from the reports I see as I research these failures.
There are applications running in the back ground such as FB, LinkedIn, My space...etc. There is a setting you can turn off how your phone uses apps. You are able to turn them on and off to keep from streaming update data.
Im guessing that the app/game was corrupt or incompatible with your tablet. You will have to reset your tablet to factory settings and restore your apps and other items from google, if you had it set up for this. To do a reset go to settings - about tablet - reset - factory. Then let it restart.
When you reset the tablet your tablet wifi settings, wifi name and password will be erased. You have to detect your wifi on the tablet, connect to it and enter password right?
I had the same thing happen to my Digix Tab 720 last night. This happened after I reset the tablet to factory settings. I left it charging over night and this morning, it is working perfectly. Hope this helps.
