SOURCE: GN 9350 Wireless Headset doesn't ring on the headset when phone rings
It only picks up certain digital rings. I changed the ringer on my phone and had the same problem. To fix it, I had to plug in the little microphone that plugs into the handset lifter and place the mic over the ringer speaker. Now it works fine.
SOURCE: connecting headset to phone
Setup the Plantronics CS60 wireless headset as follows:
To be able to hear or speak through the handset,
either place the headset back into its charging cradle or press the
call control button on the side of the headset. The talk indicator
light on the base should go off and no sound will come through the
headset.
Note: Make sure that the cables are connected correctly and the handset cable is connected to the base of the CS60 base.
SOURCE: how to reset bluedio av890
very simple...hold the call button and the play/pause button while startin the unit up...the led will blink blue thrice and will continuously stay on confirming the reset mode...u can now view the headset as AV890 on ur phone or pc....the code is 0000...confirm it and the connection is authenticated...done...q.e.d
Do you happen to have the operating instructions as I have lost mine?
