Switch it off.
Press the on off switch for little long duration, till the Light glows steady/permanent (without blinking).
At this stage it can be connected to a device enabled with Blue tooth in "switched on" condition using the passcode "0000" (four times zero)
MUTHUPETCHI V ([email protected])
For reseting the pair of Bluedio AV890S from existing mobile and to connect it to different Mobile. In Switch off condition of Bluetooth Head set first, press and hold the On-Off/call/answer key for few long period. Blue light starts blinking, don't release the keys, hold it further,then the blue light stops blinking, then release key. Now in your mobile handset search for devices with blue tooth set to on. When it shows AV890s pair it and it will get connected.
(Eventhough if AV890s is not UNPAIRED with one handset devices it gets connected to another mobile handset.)
My bluedio hurricanes flash red and blue when I put it onto paring mode? How do I fix this
My Bluedio av890 Is not getting charged itself.help me finding a solution to it.Plzzzz.....................................
SOURCE: bluedio av890 is not detected............
It is very simple yaa. Instructions are given in the user manual itself.
Switch off the Head set first. Press and hold the On-Off/call/answer key for few long seconds. First the blue light on with blinking. Don't release the switch, hold it further. Then the blue light stops blinking and shows a steady/stable/permanent glow. Now try from your mobile phone with blue tooth set to on. Search for items. On getting the indication of AV890s presence press "connect" switch. Password or Code to connect is "0000" (four times zero).
Now AV890 IS CONNECTED TO YOUR CELL PHONE. O.K.
MUTHUPETCHI V- MADURAI ([email protected])
SOURCE: how to reset bluedio av890
