Just because an igniter glows, does not necessarily mean it is good. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
An easy way to determine an igniter problem without taking current readings is to test both oven features. Since there is a separate igniter for bake and broil, and both are fed from the same gas source, if the broiler works, but the bake feature doesn't, you more than likely have a bad igniter.
Read through the information provided and let me know if you have any questions. I hope this helps you.
There must be a MINIMUM of 2.9 amps at the ignitor to work correctly to bring on the gas valve. Less than 2.9 replace the ignitor. More than 2.9 replace the gas valve.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
gfgshg
heatman101
ssgs
