Jul 29, 2009 - I need a power cord for a Nostalgia Electrics Chocolate Fondue Fountain model CFF-884. - Nostalgia ... Also, our new website is www.nostalgiaelectrics.com ...SOURCE: I have a chocolate fountain. model # CFF-900 and.
press on the MR/C (set) button. This button is located on the calculator buttons area of the watch. Hold this button until the date begins to blink. you select the numbers you want to set the date and time to by pressing the correspondent numbers on the key pad. once the date and time is set press the enter key.
Did you mange unscrew the crown first and then pull it out? If you have already did it, then there is a problem with setting lever. Usually it happens when the moisture builds up in the watch, resulting parts covered with a layer of rust.
If this is the case, you will need professional watchmakers help.
You are undertaking quite difficult task. I'm not very sure that the assembling the watch from separately bought parts will be cheaper than the complete watch itself. Anyway, if you decided to do so- go ahead. First you have to consider what type of watch you want- mechanical or quartz. Second - what features would you like: simple classical layout, type of seconds hand, chrono layout, maybe with subdials and so on e.t.c. Let me know all this and I will guide you through all the stages and may even help with part supplies. Make can be considered later as very many watch parts are interchangeable.
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
