Split system starts with remote then system shuts down
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
SOURCE: LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
SOURCE: LG remote problem
Most probably if the remote works on the other units then the receiver on your problem unit is busted. You have to call an authorized service repair shopr to replace the board.
I hope it helps.
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
SOURCE: i have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
