I was printing and I got the red like and error message C3452on my Konica Minolta bizhub C352. Help!
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
SOURCE: Konica Minolta Bizhub C352 error code C-0204
I had the same recently.
Problem is caused by a paper which stuck behind the paper tray. It
happens when You put to much paper od while moving (for example).
Solution: take out the paper tray 1 and 2, remove the paper from the
space behind the trays.
Pixel
www.mojito-networks.com
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
