4.5 MIXER, NEEDS SPEED CONTROL LEVER REPLACED
Here is a diagram of your unit. Whirlpool Mixer K45SSWH 0 Parts List
SOURCE: Speed control lever stuck or locked. How do I unlock it?
Hi BROOKLYNX. To answer you primary question, no there is no special speed control knob lock that you?ve inadvertently triggered. OK, so without a lock why?s your speed control knob stuck? It most likely that something broken inside your mixer to lock it into position. I wouldn?t continue to operate your machine as you are doing. It?s not good for the electric motor, the electric cord or the plug. It would be better to determine the root cause of your control knob?s obstinacy. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. You?ll want to focus on part #s 2, 3, 4, 5, and 6, which is our speed control assembly. Check to see if something isn?t blocking you?re the movement of #3. You should be able to determine if something has broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
SOURCE: how do i replace the speed control lever
Hi TONY961. Replacing your speed control lever is a pretty simple repair job. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KSM90P, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus Nos. 1, 2, 3, 4, which are Pivot screw, Spring washer, Switch lever and stud, and Control plate spring respectively. Disassemble your mixer to the point of accessing your speed selector assembly, and inspect the pivot screw to see if it hasn’t worked itself loose over time. That’s the simplest thing to fix. If loose, tighten. Inspect the rest of the assembly to determine if something else hasn’t broken or gotten out of alignment. If something has broken, you can order replacement parts and install them yourself.
While your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
If this solution was helpful, please rate it, thanks! – hslincoln
Testimonial: "very helpful just wasnt sure how far to disassemble to get to speed control thanks again"
SOURCE: mixer only moves at one speed
Referring to the following parts description:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
The speed is controlled with a combination of the governor assembly #24 which mounts on the motor shaft, and the phase control board #27 which is mounted on the back of the mixer.
They operate in conjunction with item #25, the control plate assembly.
WARNING SHOCK HAZARD. FOLLOW THESE STEPS ONLY IF YOU ARE COMPETENT WORKING AROUND HOT ELECTRICAL COMPONENTS AND FOLLOW ALL SAFETY PRECAUTIONS!!!
Remove the rear cover screw #37 and the rear cover #36 and examine the governor when it is running. Also watch the speed control lever mechanism as you move it from off to the highest speed watching for binding etc.
Make sure that the spring #4 is attached to the bottom of the control plate #25.
If the governor appears to be opening and closing as the speed increases and the linkage is not binding then the problem is most likely the Phase Control Board, item #27.
SOURCE: How to replace KitchenAid KSM75WH Speed Control
Hi
PC1546. Replacing your speed control
Click
Guides> and select “Consumer” for User Type, then enter the 6 character Model
Number, in your case, KSM75W, and select the file listed under Parts List (1) KSM75WH1.pdf (341.26 KB)
and save that to your computer. (Check that it matches your mixer model).
Turn
As
far as parts go, here are five potential online vendors in no particular order:
RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do
some comparison shopping.
While
Here
of a KA Mixer.
Between
your mixer.
Good
SOURCE: The kitchenaid speed lever is bent and jammed
Hi TIMDEIST, I hate it when you drop your mixer... they’re really not designed for gravity testing. Let’s see what you can do to get it fixed and operable again. The good news is that this can be fixed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals& Guides> then enter the visitor type “Consumer” and enter the 6 character model number, in this case K45SSW, and then select the file under Parts List (1) K45SSWH0.pdf (341.41 KB) (definitely check to see it this matches your mixer).
Although not providing step by step instructions, the Parts List manual provides an exploded view of the various component assemblies allowing you to see how the mixer all fits together. It is helpful for the disassembly, troubleshooting, and reassembly of your mixer.
Turn to pages 6 & 7, titled “Motor And Control Parts”, and locate Ill. Nos. 1, 2, 3, & 4. #3 is your Switch Lever and stud. If you can’t straighten it out then you will need to replace it. It might also be a good idea to check and see if anything else might be out of alignment due to the sudden stop when it was dropped.
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping. Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, fix/replace your Switch Lever, and reassemble your mixer.
Good luck, I hope this helps. Howard, Burke, VA
